Thanks kszaq for the reminder in your pm. Unless YOU tell me there are benefits in the s905 that will wow me, I'll be sticking with beelink S805.
The advantages of S905 over S805 are:
- 4K H.264 and HEVC decoding
- 10-bit HEVC decoding
- improved performance
Additionaly, with WeTek Hub you get full DRM support in Android, i.e. Netflix, Amazon Prime Video in full resolution.
If you don't need any of those, S805 is completely fine.
1. Each box will usually lockup a 3 or 4 times a week on me. I have to unplugg it and then press the power button to power it back on. I'm not sure if this is only happening with MXV or if it also happening with the MXQ with red stripe as well. Im guessing it probably just the MXV since its not really supported by you. I haven't grabbed a error log file from it afterwards but I will the next time it happens. Can I post it or send the log to you when it does?
A few things you can try doing to resolve this:
- use 7.0.1.4 and MXQ build (it is reported to work better with MXV)
- if you're already on 7.0.1.4, try switching back to hotplug governor by putting echo "hotplug" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor in autostart.sh
- if after a lockup you can still connect over Samba and/or SSH, this is a Kodi lockup and not system lockup. I would blame addons in this situaltion.
2. The remote arrow keys have a tendency to stop responding whenever you double click the up or down arrow key very quickly. I'm not sure if this is just becuase of the double click or a physical flaw the remote design itself and it acuatlly hits the mouse pointer button because of the board is bowing inside the remote case. However it may be a combination of both or could it be the remote config file causing the problem. The workaround for whenever the remote arrow keys stop responding is to just press the mouse pointer button once and the arrow keys will start working again. Does anyone else have this same issue with the MXV remote?
You can disable switching to "mouse pointer" mode by commenting line with fn_key_scancode in remote.conf - simply put # in front of the line.
3. The home button doesn't work. I tried using the Keymap editor addon to fix this issue but it will not fix the problem. So I am wondering if I can manually edit the remot.config file to fix this issue? If so do you have a link on configuring and editing the remote config files? Or does someone already have a remote config file for the MXV that has the Home button working?
To resolve this you should replace keycode for Menu button in your remote.conf (look at kmsg to tell which one) or wait for a next build where I'll include a script that remaps remote buttons in custom remote.conf.
4. I can not reboot the MXV from the homescreen but I can shutdown the MXV from the homescreen. Before I upgraded to Librelec I believe you had gotten it to not only shutdown but to also reboot. You of course fixed the usb male to male cable in port 1 and 4 issue..... Which was Awesome BTW!
Reboot works just like before (i.e. in OE builds), it must be something else that changed. For now you can work this around by choosing "Power off" and powering the box back on.
ok but where exactly is the "Configuration folder?"
/storage/.config over SSH or \\[i]your_box_IP[/i]\Configuration using Windows shares.
