[7.0.3.3d] LibreELEC 7.0 for S805
  • Can you try running this in SSH terminal:
    echo audio_off > /sys/class/amhdmitx/amhdmitx0/config
    echo audio_on > /sys/class/amhdmitx/amhdmitx0/config
    Don't worry about sh: write error: Bad address that comes out when executing. Does audio turn on after this?
    No audio still.
    But also i noticed if i turn the device on with the tv off and turn the tv on once its booted it works fine and the tv has detected it.
    Edited once, last by AuXBoX ().
  • No audio still.
    I know this sounds stupid, but have you tried a different HDMI cable. I've had some problems with the ones supplied with the boxes.
    Sent from my SM-G928W8 using Tapatalk
  • pigbait i have tried three different ones with no luck.
    Have you tried turning CEC off on your TV ?
  • Have you tried turning CEC off on your TV ?
    Yeah i have and on Kodi.
    I'm thinking of putting android back on and changing the CEC settings on that then flashing LibreElec back to NAND.
    Would that effect LibreElec at all? Cause i know it effects the resolution on bootup from when i was playing around with previous problems.
    thanks for the assistance also guys
  • Yeah i have and on Kodi.
    I'm not sure if you have more than 1 HDMI port into the TV ?
    I guess you have tried a different one if you had one ?
    Sorry if i am asking the obvious.
  • kostaman
    Yeah i have tried another port and still the same.
    What setting do you have in Settings\System\Audio Output\Audio Output Device ?
    MK808b Plus stick running LibreElec 7 with Retroarch 1.3.6 running as an addon
  • sammaz
    I'm not home at moment but from memory:
    SPDIF was the only one that worked if i unplugged the hdmi cable and plugged it back in AND if i left tv off till LibreElec booted and i turned the Tv on.
    ANALOG worked if i unplugged the HDMI cable and plugged back in only.
    I'm pretty sure thats what happens
  • Are you on 60hz or 24hz.. with my box I get no audio if i set it to 24hz in the display setting.
    60 but i have tried 50 and both the same
  • AuXBoX: If you want to disable CEC at powering on, you can execute fw_setenv cecconfig cec0. This will have the same effect as disabling CEC in Android.
    That didn't work either.
    I'ts something during the bootup process. At the very start
