Common DVB-T DVB-S dvb-c topic
  • "- dvb-t has bug in driver, impossible to fix in tvheadend;"
    what bug?
    cannot take the driver from android release?
    There work everything.
  • Thanks.
    Will there be a krypton build with this internal tuner support? No rush or anything though, just curious. :)
    For my use of tvheadend, when watching on K2 pro SD channels often get stuttering. But when watching from other client with Kodi Krypton, that issue never occur.
    So I think this is due to Kodi Jarvis somehow.
  • Thanks for your work afl1.
    Unfortunately, we still are problems
    linuxdvb: Availink AVL6862: DVB-S # 0 - failed to config dmx for pid 474 [e = Operation not permitted]
    full log tvh:
    GY35in7G
    I don't see any problems. Log for transponder 11526H 13E shows the scan was successfully completed.
    "failed to config dmx..." means this kind of service is unsupported by this receiver. I tested this transponder in my box with 30 scanned services (lot of radios) and status OK. I can watch SRF info HD, SRF 1 HD and SRF 2 HD.
  • I don't see any problems. Log for transponder 11526H 13E shows the scan was successfully completed.
    here had the same problem
    OpenELEC 5 with DVB-S2 - WeTek Community Forum
  • very much transporters is fail because I do not have all the channels hotbrid 13E
    2016-11-04 23:01:45.777 mpegts: 12731H in 13E - scan no data, failed
    2016-11-04 23:01:35.767 mpegts: 12692H in 13E - scan no data, failed
    2016-11-04 22:39:12.064 mpegts: 10723H in 13E - scan no data, failed
    2016-11-04 22:39:22.165 mpegts: 10775H in 13E - scan no data, failed
    2016-11-04 22:39:32.275 mpegts: 10853H in 13E - scan no data, failed
    2016-11-04 22:39:52.275 mpegts: 10815H in 13E - scan no data, failed
    2016-11-04 22:48:03.165 mpegts: 12539.02H in 13E - scan no data, failed
    2016-11-04 22:48:13.237 mpegts: 11919V in 13E - scan no data, failed
    2016-11-04 22:57:01.818 mpegts: 12322H in 13E - scan no data, failed
  • It is impossible to receive all transponders from Hotbird, becaase every transponders has its own beam direction and can hapend it is out of your country. Also UHD is still not correctrly supported and at last check parameters for transporder. In downloaded database is lot of wrong values.
  • i tested vitmod v2 rc6 with k2pro.dtb and replace rc6 enigma2 folder usr/lib/enigma2 with rc5 enigma2. the broken gui fixed. dvbs2 working well. i attached here some pictures. i use LAN Nework for internet.
    Use KODI first to telnet and ftp, use client like PuTTY, SSH, SFTP, WinSCP. User:root Pass:root.
    here from someone:
    For someone is looking for Enigma2 running on K1 Plus & K2 Pro. I already modified an image from Vitmod RC6. Its all works fine in Enigma2. Channel can scan very well. GUI already fix. But still looking for OSCAM. I already upload to my server but for your information its 3.7GB because it its an image backup from 4GB Sdcard. Here is the link:- K1 Plus Vitmod RC6 (Modification) Version: K1PlusRC7.img K2 Pro Vitmod RC6 (Modification) Version: K2ProRC7.img Thanks to Vitaly for great works. I hope @Vitaliy_S can make an OSCAM-emu working with Enigma2.
    hi
    for enigma i found a openpli for s905
    " sd image: MEGA
    you need to copy your proper dtb into boot partition as boot.dtb. You can find it at device_trees
    If you have odroidC2 you need to revert back the boot.ini (I created a special boot.ini for media boxes). If you have a S905 box you can use the toothpick method to boot."
    can you add a boot and tuner?
    tnks
    Edited once, last by algdu83 (November 19, 2016 at 11:40 AM).
  • This means that it don't work with dbv-t?
    Anyway, the driver work with other backend, so I think that IS POSSIBLE fix it in tvheadend.
    William Fanelli
  • I can not download file. File not found
    Edited once, last by messert (November 8, 2016 at 10:31 AM).
