My Libreelec is not capable of Dolby Digital Plus DD+ passthrough on Raspberry! Help
  • Audio is working, so no idea what you mean by DD+ default values...
    I didn't said that. I was talking about "suggested default values", which of course refers to my statement before (posting #28).
    Do you mean, DD+ is working on Netflix now, and my suggestion of posting #28 was successful?
    mglae:
    Yes, I was interested in that E-AC-3 setting line too, because DD+ actually is E-AC-3. I figured out that a reboot will always set this value back to "false", if one tries to edit it. So, my conclusion is that we are not talking about DD+/E-AC-3 pass-through here, because other RPi users got it working.
    Flexin' vinyl, jammin' break beats. 8)
    Edited once, last by Da Flex ().
  • Da Flex,
    no I don't have DD+ with the suggested settings. Neither on Netflix nor anywhere else. I have answered your post in #29 and also noggin did and it works that way.
    If you disable passthrough you will get by Kodi decoded PCM sound. It is a possibility to get sound working, but not they way I want it.
    Also you are wrong with the eac3 setting, which is of course DD+ and a visible setting in the audio section and the only switch to deal with if you want to handle DD+. It won't get disabled after reboot. And it is disabled in my settings because I did so. And I did so because
    "My Libreelec is not capable of Dolby Digital Plus DD+ passthrough on Raspberry"
    LibreELEC (Leia) on Raspberry Pi 4B
  • sure
  • Also you are wrong with the eac3 setting, which is of course DD+ and a visible setting in the audio section and the only switch to deal with if you want to handle DD+.
    1. Set your skin to default, and DD+ is not visible as a pass-through setting. It's invisible for a reason.
    2. Check the real values of guisettings.xml (cat command).
    3. Copy a guisettings.xml from someone who got DD+ working.
  • Maybe just get a spare SD card and do a fresh install. It will save a lot of time and if you were so inclined you could even try some older versions of LE to see if you are experiencing a regression.
    I will post my guisettings.xml if it helps.
  • Sure, I will post it shortly.
    I notice in your settings above that you have the close-tag <defaultaudiosettings /> but I cannot see a correspoding start-tag. (line 358)
    I don't know if it is in any way relevant.
  • I notice in your settings above that you have the close-tag <defaultaudiosettings /> but I cannot see a correspoding start-tag. (line 358)
    An element with no content can be a start-tag immediately followed by an end-tag. Called self-closing tags
  • Just cloned my Kodi backup over to Raspi4 / LE 9.1 and... there it works.
    Without any change of settings.
