Running 9.0.1 on RPi2
Have connected a 2Tb WD drive via powered hub
The drive is formatted to ext4 and fully readable on my Solus desktop machine
Navigating the LE file manager to /var/media shows my drive but if I enter it none of the 5 directories on it are visible.
Same if I `ls /var/media/WD2Tb_drive` Over ssh - nothing seen on the drive.
So it seems to have been mounted but... why aren’t the directories visible or navigable?
I have an almost identical 2Tb WD drive attached to my home server for Plex. Only difference is that it’s NTFS file system. If I attach that to the RPi everything works fine.
Any tips would be helpful. I’ve done `dmesg `df -h` etc. but can’t seem to think of a way forward in my investigation!
