I have a docker container running with PulseAudio inside. Where should I create a docker volume to from LibreELEC, so PulseAudio can detect the correct device from the container, or so I can manually set it as a sink (output)?
And is it possible to have LibreELEC use the device alongside the docker container, or will I need to use separate outputs?
Appreciate any directions.
