Since updating to Liea, my machine (standard x86 hardware) is running noisy on the menu's.
I logged into (ssh) to try and install some fan speed control / lm-sesnors.. but can't as the distro is limited (no Git, Make, Apt, GCC)
Any advice?
Any advice?
I have no advice how to control fan speed by LE. The GUI is running significantly smother since 9.0, so I think multi-threading is the cause. That's a sign of good programming.
You can connect the fan cables directly to the PSU. Then you have constant fan speed, which is maybe not that loud.
I think if you're having fan noise then it's more than likely that something is using tooooo much cpu.
Please provide a screen shot via ssh of top
Also the URL form dmesg | paste
and
Thank you for your response's.. just going to update to 9.0.1 to see if there is any change
So it appears its kodi.bin, its using around 49 % when just sat in the menu.
Any ideas?
Any ideas?
See post #3
Any ideas?
See post #2 (it's a proof of my GUI theory)
