I know LOL, this thread is over a year old but me too I would like to revive my MK808b+ so if anyone still has the files i would be grateful if you could send them my way
Cheers,
Luc
Cheers,
Luc
Hi, I'm in the same situation here.. need a copy of the LibreELEC S808B+ firmware please
My HD18Q image from the LE 9.2 branch can be used on the MK808B+, but unfortunately bluetooth won't work.
If this doesn't bother you, you can find the image here: http://libreelec.dtech.hu/S805/
Related topic:
Brilliant, thanks I don't really need Bluetooth, so that will be no problem.
hey dude thanks for that! I had one in a box from donkies years ago and just updated from 7.90beta4 lol
it still has an openelec splash screen on boot, any idea how to get rid of that?
and even though it says CEC connected on startup it doesn't recognise my Samsung remote?
thanks again!
Well, that's very interesting, because the LibreELEC logo is part of the initramfs, which is in the kernel.img.
If you are running LE from an sd card, please enter this command under SSH:
If you do not get this result: ec3c1d0e0774093d2eabf6deb599f28f, the update failed for some reason.
(But if you are running LE from NAND, this command will not work, because there is no kernel.img under the "flash" mount point.)
Try to enable CEC manually in uboot:
Then restart the box...
dtech no sd card, I must have had openelec on there before I installed libreelec and I think it's getting the openeelec logo in something like 'bootloader config' before kodi even loads?
where do I find the uboot settings?
cheers
Can I get a dmesg and an fw_printenv output?
1080ioutputheight=1047
1080ioutputwidth=1863
1080ioutputx=28
1080ioutputy=16
576ioutputheight=559
576ioutputwidth=699
576ioutputx=10
576ioutputy=8
720poutputheight=667
720poutputwidth=1185
720poutputx=47
720poutputy=26
baudrate=115200
bootcmd=run storeboot
bootdelay=1
bootfile=boot.img
bootm_low=0x00000000
bootm_size=0x80000000
bootpath=u-boot.bin
bootsize=100000
bootstart=0
cecconfig=cec0
chipname=8726m8
console=ttyS0,115200n8
cvbs_drv=0
cvbsmode=576cvbs
digitaudiooutput=PCM
display_bpp=24
display_color_bg=0
display_color_fg=0xffff
display_color_format_index=24
display_height=1080
display_layer=osd2
display_width=1920
ethaddr=00:15:18:01:81:31
fb_addr=0x7900000
fb_height=720
fb_width=1280
firstboot=1
gatewayip=10.18.9.1
get_dt=checkhw
has.accelerometer=false
hdmimode=720p
hostname=arm_m8
initargs=init=/init console=ttyS0,115200n8 no_console_suspend storage=1
initrd_high=60000000
ipaddr=10.18.9.97
loadaddr=0x12000000
loadaddr_logo=0x13000000
mmcargs=setenv bootargs console=${console} boardname=m8_board
netmask=255.255.255.0
normalsize=400000
normalstart=1000000
outputmode=720p
p0path=uImage
p0size=400000
p0start=1000000
p1path=android.rootfs
p1size=8000000
p1start=1400000
partnum=2
preboot=if itest ${upgrade_step} == 3; then run prepare; run storeargs; run update; fi; if itest ${upgrade_step} == 1; then defenv; setenv upgrade_step 2; saveenv;fi; run prepare;run storeargs;get_rebootmode; clear_rebootmode; echo reboot_mode=${reboot_mode};run update_key; run switch_bootmode
preloaddtb=imgread dtb boot ${loadaddr}
prepare=logo size ${outputmode}; video open; video clear; video dev open ${outputmode};imgread res logo ${loadaddr_logo}; unpackimg ${loadaddr_logo}; logo source ${outputmode}; bmp display ${bootup_offset}; bmp scale;
recovery=echo enter recovery;if mmcinfo; then if fatload mmc 0 ${loadaddr} recovery.img; then bootm;fi;fi; if usb start 0; then if fatload usb 0 ${loadaddr} recovery.img; then bootm; fi;fi;if imgread kernel recovery ${loadaddr}; then bootm; else echo no recovery in flash; fi;
sdc_burning=sdc_burn ${sdcburncfg}
sdcburncfg=aml_sdc_burn.ini
serverip=10.18.9.113
store=1
storeargs=setenv bootargs ${initargs} cvbsdrv=${cvbs_drv} vdaccfg=${vdac_config} logo=osd1,loaded,${fb_addr},${outputmode},full hdmimode=${hdmimode} cvbsmode=${cvbsmode} androidboot.firstboot=${firstboot} hdmitx=${cecconfig}
storeboot=echo Booting...; if unifykey get usid; then setenv bootargs ${bootargs} androidboot.serialno=${usid};fi;imgread kernel boot ${loadaddr};bootm;run recovery
switch_bootmode=if test ${reboot_mode} = factory_reset; then run recovery;else if test ${reboot_mode} = update; then run update;else if test ${reboot_mode} = usb_burning; then run usb_burning;else if test ${wipe_data} = failed; then echo wipe_data=${wipe_data}; run recovery;else fi;fi;fi;fi
testaddr=0x12400000
update=run usb_burning; if mmcinfo; then if fatexist mmc 0 ${sdcburncfg}; then run sdc_burning; else if fatload mmc 0 ${loadaddr} aml_autoscript; then autoscr ${loadaddr}; fi;run recovery;fi;else run recovery;fi;
update_key=saradc open 0; if saradc get_in_range 0 0x50; then msleep 50; if saradc get_in_range 0 0x50; then echo update by key...; run update; fi;fi
upgrade_step=2
usb_burning=update 1000
vdac_config=0x10
video_dev=tvout
wipe_data=success
Display More
and....file attached
thanks!
Everything looks good from the kernel side, I think the boot logo has been replaced by a custom ROM. If you can tolerate to see the OE logo appear on startup, you don’t have to deal with it because it doesn’t affect anything. However, if this bothers you, you will need to restore the factory Android ROM (this will restore the boot logo) and then install the LibreELEC image from the SD card to the NAND (with installtointernal script).
And to make CEC work, the fw_setenv cecconfig cec1f I wrote earlier must be run, because fw_printenv says it's still turned off:
