oscam-emu service (addon)
  • Any chance someone can share the latest oscam-emu for libreelec 9.0 ( generic X86 -64 )
    I can only find some builds for ARM based processors ( libreelec for s905/912 boxes etc)
    Thanks...
    I am insane! My mother had me tested.
  • No reply at all means
    1. i should either change OS or
    2. if i insist in using Libre i should buy some of those "all-in-one" Chinesee boxes,
    am i correct? Maybe i m missing something
  • Many thanks L... i appreciate your help ...
    I will definitely try!
    6 more people already downloaded before me (!!!), so it looks like more people need it,
    i m hoping whenever someone has a newer version to post it here and keep this topic alive with updates
  • Edit, April 10: File deleted.
    Here is an update for anyone needing the latest emu version
    First, install service from Livs post above.
    As explained do not update ( you can disconnect the internet when installing, and re connect after you uncheck the "auto update" button in Kodi ( My addons > services ) to prevent future updates
    The, replace the oscam file found in folder .kodi\addons\service.softcam.oscam\bin with the one attached in my post
    Emu version 791
    In my case, it works fine with Milhouse latest nightly :
    Edited once, last by infoalter: 20 downloads, not a single "thanks" - File deleted ().
  • i use ubuntu. should i just run make? Any special configs for Libreelec? Later after building, just replace the old bin?
  • i did it like this in a ubuntu vm and it worked for me
    install everything needed to compile oscam
    sudo apt-get update && sudo apt-get install build-essential subversion libssl-dev libpcsclite-dev libusb-1.0-0-dev dialog pcscd
    get the latest build from the official oscam svn
    svn co http://www.streamboard.tv/svn/oscam/trunk oscam-svn
    configure the build with all the options i need (like smartcardreaders etc.)
    cd oscam-svn
    make config
    build it with libusb support (not sure if this is needed or a simple make does the same job...think i accidently build it once with PCSC support. libreelec doesnt have the pcsc librarys and it didnt work than...so thats why i used this)
    make USE_LIBUSB=1
    when the build is complete
    cd Distribution/
    and there should be your new shining oscam build similar to a filename like this
    oscam-1.20_svnXXXXX-x86_64-linux-gnu-libusb
    copy it to your librelec box into
    /storage/.kodi/addons/service.softcam.oscam/bin/
    give it a test run with --help to see if it pops any errors
    disable the oscam addon in kodi for now
    rename the old oscam binary to oscamold (for backup purpose)
    rename the new oscam binary to oscam and make sure its chmod 755
    enable oscam addon in kodi
    profit.
    Edited once, last by rofn ().
  • there are already pullrequest made for LE oscam: update to 11517 by CvH · Pull Request #3461 · LibreELEC/LibreELEC.tv · GitHub
    Compile [LibreELEC.wiki]
    PROJECT=RPi DEVICE=RPi2 ARCH=arm scripts/create_addon oscam
    you need to edit LibreELEC.tv/package.mk at master · LibreELEC/LibreELEC.tv · GitHub
    latest version is a2ee0528f1de527748aaf7a79982ed112ffa3183 Public Git Hosting - oscam.git/summary (click commit and you see the hash)
    you can delete this line LibreELEC.tv/package.mk at master · LibreELEC/LibreELEC.tv · GitHub or you need to change it to the sha256 hash of the coscam.tar.gz that is downloaded from the url above
    is just cosmetic but you can change it to currently 11517
    I am not too sure when the update is rolled into the addon repo as our buildserver has some random issue at the moment.
