Retroplayer - ScummVm
- movedoa
- Thread is Unresolved
One solution is https://forum.libreelec.tv/cor…/67-scummvm-linker-error/
I am using Libreelec for a RPI2. I tryed to access the link above, but I am not authorized to access this page. What is going on?
It would be very good if I could downgrade my version of scummvm. Is there still any older version that works?
Thanks!
Hi, are here any news to this topic? Could I offer any help to fix this issue?
BR
I thought i would register here to post what i have found by reading all the way to the end of the internet
from what i found, this is an issue when scummvm is compiled directly on the raspberry pi from the Repo (again, im a newb, my wording might be wrong), so i found one that was manually compiled on a computer, i have attached it here, you can manually install this version on your PI and it should work (it works for me)
i can host this for now on my private server but if someone could host it somewhere public that would be appreciated :
Rock Here you go: game.libretro.scummvm-2.1.1.9.1.zip
hello... it's me again...
i just switched from LibreELEC 9.2.8 for RPi3 to the new offical LibreELEC 10.0.2 for RPi3 and i have to say, unfortunately i have the issue again with the ScummMV add-on (v2.1.1.23.1)...
the add-on does not start on LibreELEC 10.0.2Code2022-04-24 16:22:46.071 T:673 INFO <general>: CAddonMgr::FindAddons: game.libretro.scummvm v2.1.1.23.1 installed 2022-04-24 16:23:14.506 T:673 INFO <general>: RetroPlayer[PROCESS]: Created process info for GBM 2022-04-24 16:23:14.542 T:673 ERROR <general>: ADDON: Dll ScummVM - Client returned bad status (5) from Create and is not usable 2022-04-24 16:23:14.543 T:673 INFO <general>: Loading skin file: DialogConfirm.xml, load type: KEEP_IN_MEMORY 2022-04-24 16:23:16.379 T:673 ERROR <general>: RetroPlayer[PLAYER]: Failed to initialize game.libretro.scummvm 2022-04-24 16:24:05.205 T:673 INFO <general>: RetroPlayer[PROCESS]: Created process info for GBM 2022-04-24 16:24:05.211 T:673 ERROR <general>: ADDON: Dll ScummVM - Client returned bad status (5) from Create and is not usable 2022-04-24 16:24:10.296 T:673 ERROR <general>: RetroPlayer[PLAYER]: Failed to initialize game.libretro.scummvm
is it still the same issue?
yes we still face the same issue and still can't reproduce what happens
we switch to a new buildings infrastructure soonish so our hopes are high this is fixed or we can at least reproduce it
thanks for answering...
unfortunately i can't build it by my self (https://wiki.libreelec.tv/development-1/build-basics),
i switched to the new ubuntu 22.04 LTS and it seems there are some build dependency i can't resolve. -
i switched to the new ubuntu 22.04 LTS and it seems there are some build dependency i can't resolve.Try using the docker build. It covers off the dependencies.
LibreELEC.tv/README.md at master · LibreELEC/LibreELEC.tvJust enough OS for KODI. Contribute to LibreELEC/LibreELEC.tv development by creating an account on GitHub.github.com -
Isn't still reproducible on build server if the issue is still present.
it is always broken at the buildserver, but we have no direct access so debuging is a bit difficult
the problem should solve itself the one or the other way
