And is HD-AUDIO (trueHD, Master audio ) passtrough also working?
Does not work properly for me. Every couple minutes i get a half second of dropped audio. Could you test it out on your setup to confirm?
Yes i will do that.
What is your setup?
What avr do you have and what tv?
i have a onkyo tx-nr555 connected to my lg CX.
Vizio TV hooked thru a Denon AVR
So NUC11 Pro still has PCON chip but connecting to DP1.4a.
As the LSPCON was the reason why the other NUCs cant do HDR on LE properly, does this newer version with DP1.4 change that or will we still need the patches?
It will probably work fine, support in Linux is already there.
hmm so far only the people with gemni lake nucs got HDR working without bitstream audio. unless I missed it and people with NUC8 or 9 have these builds working with HDR?
There is no HDR support in Linux for legacy LSPCON chips. Patches exist but they have not been merged (yet).
PCON DP 1.4 -> HDMI 2.1 is already properly supported. I see no reason why there would be an issue with HDR.
Ah ok
The new NUCs dont have HDMI 2.1 though only 2.0a
A user reported that HDR does not work with my build on NUC11PA.
Not yet. I try to figure out if it does have a PCON chip. NUC documentation says it does. But it does not make sense because Tiger Lake-U has a native HDMI 2.0 controller.
ok
hope the person with it can supply you with logs etc
i think it does have p con as intel board diagrams not wrong. Gemini lake NUC board diagram shows no LSPCON and HDMI direct to CPU but all others have it in diagrams
Thanks to @luckylukz it's now confirmed that NUC11PA does indeed use a DP->HDMI protocol converter.
The driver detects 5 available connectors: DP-1, DP-2, DP-3, DP-4, HDMI-A-1.
"HDMI-A-1" is a native HDMI but it is not active when the TV is connected to a NUC's HDMI port. DP-3 is actually active which means that a PCON is used.
trying to open device 'i915'...done
Connector 276 (DP-1)
1 EDID:
flags: immutable blob
blobs:
value:
2 DPMS:
flags: enum
enums: On=0 Standby=1 Suspend=2 Off=3
value: 3
5 link-status:
flags: enum
enums: Good=0 Bad=1
value: 0
6 non-desktop:
flags: immutable range
values: 0 1
value: 0
4 TILE:
blobs:
value:
281 subconnector:
flags: immutable enum
enums: Unknown=0 VGA=1 DVI-D=3 HDMI=11 DP=10 Wireless=18 Native=15
value: 0
282 audio:
flags: enum
enums: force-dvi=18446744073709551614 off=18446744073709551615 auto=0 on=1
value: 0
283 Broadcast RGB:
flags: enum
enums: Automatic=0 Full=1 Limited 16:235=2
value: 0
284 max bpc:
flags: range
values: 6 12
value: 12
285 Colorspace:
flags: enum
enums: Default=0 RGB_Wide_Gamut_Fixed_Point=13 RGB_Wide_Gamut_Floating_Point=14 opRGB=7 DCI-P3_RGB_D65=11 BT2020_RGB=9 BT601_YCC=15 BT709_YCC=2 XVYCC_601=3 XVYCC_709=4 SYCC_601=5 opYCC_601=6 BT2020_CYCC=8 BT2020_YCC=10
value: 0
7 HDR_OUTPUT_METADATA:
flags: blob
blobs:
value:
286 Content Protection:
flags: enum
enums: Undesired=0 Desired=1 Enabled=2
value: 0
Connector 288 (DP-2)
1 EDID:
blobs:
value:
2 DPMS:
flags: enum
value: 3
5 link-status:
flags: enum
enums: Good=0 Bad=1
value: 0
6 non-desktop:
values: 0 1
value: 0
4 TILE:
blobs:
value:
281 subconnector:
value: 0
282 audio:
flags: enum
value: 0
283 Broadcast RGB:
flags: enum
value: 0
293 max bpc:
flags: range
values: 6 12
value: 12
294 Colorspace:
flags: enum
value: 0
flags: blob
blobs:
value:
flags: enum
value: 0
Connector 295 (HDMI-A-1)
1 EDID:
blobs:
value:
2 DPMS:
flags: enum
value: 3
5 link-status:
flags: enum
enums: Good=0 Bad=1
value: 0
6 non-desktop:
values: 0 1
value: 0
4 TILE:
blobs:
value:
282 audio:
flags: enum
value: 0
283 Broadcast RGB:
flags: enum
value: 0
296 aspect ratio:
flags: enum
enums: Automatic=0 4:3=1 16:9=2
value: 0
297 Colorspace:
flags: enum
enums: Default=0 SMPTE_170M_YCC=1 BT709_YCC=2 XVYCC_601=3 XVYCC_709=4 SYCC_601=5 opYCC_601=6 opRGB=7 BT2020_CYCC=8 BT2020_RGB=9 BT2020_YCC=10 DCI-P3_RGB_D65=11 DCI-P3_RGB_Theater=12
value: 0
298 content type:
flags: enum
enums: No Data=0 Graphics=1 Photo=2 Cinema=3 Game=4
value: 0
flags: blob
blobs:
value:
299 max bpc:
flags: range
values: 8 12
value: 12
flags: enum
value: 0
Connector 301 (DP-3)
1 EDID:
blobs:
value:
00ffffffffffff003dcb301101010101
001a010380a05a780aee91a3544c9926
0f5054a1080031404540614071408180
01010101010108e80030f2705a80b058
8a0040846300001e023a801871382d40
582c450040846300001e000000fc0041
562052656365697665720a20000000fd
003a791e463c000a202020202020011b
02036df05a6160101f66650413051403
021220212215015d5e5f6263643f4038
097f070f7f071507503e06c0497f0057
06005f7e01677e006e030c002300b83c
2000800102030467d85dc401788003e3
060501e305c000eb0146d00026100325
7e73a4e20f33e200cf834f0000000000
00000000000000000000000000000086
2 DPMS:
flags: enum
value: 0
5 link-status:
flags: enum
enums: Good=0 Bad=1
value: 0
6 non-desktop:
values: 0 1
value: 0
4 TILE:
blobs:
value:
281 subconnector:
value: 11
282 audio:
flags: enum
value: 0
283 Broadcast RGB:
flags: enum
value: 0
306 max bpc:
flags: range
values: 6 12
value: 12
307 Colorspace:
flags: enum
value: 0
flags: blob
blobs:
value:
flags: enum
value: 0
Connector 309 (DP-4)
1 EDID:
blobs:
value:
2 DPMS:
flags: enum
value: 3
5 link-status:
flags: enum
enums: Good=0 Bad=1
value: 0
6 non-desktop:
values: 0 1
value: 0
4 TILE:
blobs:
value:
281 subconnector:
value: 0
282 audio:
flags: enum
value: 0
283 Broadcast RGB:
flags: enum
value: 0
314 max bpc:
flags: range
values: 6 12
value: 12
315 Colorspace:
flags: enum
value: 0
flags: blob
blobs:
value:
flags: enum
value: 0
CRTC 91
24 VRR_ENABLED:
flags: range
values: 0 1
value: 0
25 DEGAMMA_LUT:
flags: blob
blobs:
value:
26 DEGAMMA_LUT_SIZE:
values: 0 4294967295
value: 33
27 CTM:
flags: blob
blobs:
value:
28 GAMMA_LUT:
flags: blob
blobs:
value:
29 GAMMA_LUT_SIZE:
value: 262145
CRTC 152
24 VRR_ENABLED:
flags: range
values: 0 1
value: 0
25 DEGAMMA_LUT:
flags: blob
blobs:
value:
value: 33
27 CTM:
flags: blob
blobs:
value:
28 GAMMA_LUT:
flags: blob
blobs:
value:
29 GAMMA_LUT_SIZE:
value: 262145
CRTC 213
24 VRR_ENABLED:
flags: range
values: 0 1
value: 0
25 DEGAMMA_LUT:
flags: blob
blobs:
value:
value: 33
27 CTM:
flags: blob
blobs:
value:
28 GAMMA_LUT:
flags: blob
blobs:
value:
29 GAMMA_LUT_SIZE:
value: 262145
CRTC 274
24 VRR_ENABLED:
flags: range
values: 0 1
value: 0
25 DEGAMMA_LUT:
flags: blob
blobs:
value:
value: 33
27 CTM:
flags: blob
blobs:
value:
28 GAMMA_LUT:
flags: blob
blobs:
value:
29 GAMMA_LUT_SIZE:
value: 262145
Display More
Well that sucks, great job again Intel...
CodeDisplay Moretrying to open device 'i915'...done Connector 276 (DP-1) 1 EDID: flags: immutable blob blobs: value: 2 DPMS: flags: enum enums: On=0 Standby=1 Suspend=2 Off=3 value: 3 5 link-status: flags: enum enums: Good=0 Bad=1 value: 0 6 non-desktop: flags: immutable range values: 0 1 value: 0 4 TILE: flags: immutable blob blobs: value: 281 subconnector: flags: immutable enum enums: Unknown=0 VGA=1 DVI-D=3 HDMI=11 DP=10 Wireless=18 Native=15 value: 0 282 audio: flags: enum enums: force-dvi=18446744073709551614 off=18446744073709551615 auto=0 on=1 value: 0 283 Broadcast RGB: flags: enum enums: Automatic=0 Full=1 Limited 16:235=2 value: 0 284 max bpc: flags: range values: 6 12 value: 12 285 Colorspace: flags: enum enums: Default=0 RGB_Wide_Gamut_Fixed_Point=13 RGB_Wide_Gamut_Floating_Point=14 opRGB=7 DCI-P3_RGB_D65=11 BT2020_RGB=9 BT601_YCC=15 BT709_YCC=2 XVYCC_601=3 XVYCC_709=4 SYCC_601=5 opYCC_601=6 BT2020_CYCC=8 BT2020_YCC=10 value: 0 7 HDR_OUTPUT_METADATA: flags: blob blobs: value: 286 Content Protection: flags: enum enums: Undesired=0 Desired=1 Enabled=2 value: 0 Connector 288 (DP-2) 1 EDID: flags: immutable blob blobs: value: 2 DPMS: flags: enum enums: On=0 Standby=1 Suspend=2 Off=3 value: 3 5 link-status: flags: enum enums: Good=0 Bad=1 value: 0 6 non-desktop: flags: immutable range values: 0 1 value: 0 4 TILE: flags: immutable blob blobs: value: 281 subconnector: flags: immutable enum enums: Unknown=0 VGA=1 DVI-D=3 HDMI=11 DP=10 Wireless=18 Native=15 value: 0 282 audio: flags: enum enums: force-dvi=18446744073709551614 off=18446744073709551615 auto=0 on=1 value: 0 283 Broadcast RGB: flags: enum enums: Automatic=0 Full=1 Limited 16:235=2 value: 0 293 max bpc: flags: range values: 6 12 value: 12 294 Colorspace: flags: enum enums: Default=0 RGB_Wide_Gamut_Fixed_Point=13 RGB_Wide_Gamut_Floating_Point=14 opRGB=7 DCI-P3_RGB_D65=11 BT2020_RGB=9 BT601_YCC=15 BT709_YCC=2 XVYCC_601=3 XVYCC_709=4 SYCC_601=5 opYCC_601=6 BT2020_CYCC=8 BT2020_YCC=10 value: 0 7 HDR_OUTPUT_METADATA: flags: blob blobs: value: 286 Content Protection: flags: enum enums: Undesired=0 Desired=1 Enabled=2 value: 0 Connector 295 (HDMI-A-1) 1 EDID: flags: immutable blob blobs: value: 2 DPMS: flags: enum enums: On=0 Standby=1 Suspend=2 Off=3 value: 3 5 link-status: flags: enum enums: Good=0 Bad=1 value: 0 6 non-desktop: flags: immutable range values: 0 1 value: 0 4 TILE: flags: immutable blob blobs: value: 282 audio: flags: enum enums: force-dvi=18446744073709551614 off=18446744073709551615 auto=0 on=1 value: 0 283 Broadcast RGB: flags: enum enums: Automatic=0 Full=1 Limited 16:235=2 value: 0 296 aspect ratio: flags: enum enums: Automatic=0 4:3=1 16:9=2 value: 0 297 Colorspace: flags: enum enums: Default=0 SMPTE_170M_YCC=1 BT709_YCC=2 XVYCC_601=3 XVYCC_709=4 SYCC_601=5 opYCC_601=6 opRGB=7 BT2020_CYCC=8 BT2020_RGB=9 BT2020_YCC=10 DCI-P3_RGB_D65=11 DCI-P3_RGB_Theater=12 value: 0 298 content type: flags: enum enums: No Data=0 Graphics=1 Photo=2 Cinema=3 Game=4 value: 0 7 HDR_OUTPUT_METADATA: flags: blob blobs: value: 299 max bpc: flags: range values: 8 12 value: 12 286 Content Protection: flags: enum enums: Undesired=0 Desired=1 Enabled=2 value: 0 Connector 301 (DP-3) 1 EDID: flags: immutable blob blobs: value: 00ffffffffffff003dcb301101010101 001a010380a05a780aee91a3544c9926 0f5054a1080031404540614071408180 01010101010108e80030f2705a80b058 8a0040846300001e023a801871382d40 582c450040846300001e000000fc0041 562052656365697665720a20000000fd 003a791e463c000a202020202020011b 02036df05a6160101f66650413051403 021220212215015d5e5f6263643f4038 097f070f7f071507503e06c0497f0057 06005f7e01677e006e030c002300b83c 2000800102030467d85dc401788003e3 060501e305c000eb0146d00026100325 7e73a4e20f33e200cf834f0000000000 00000000000000000000000000000086 2 DPMS: flags: enum enums: On=0 Standby=1 Suspend=2 Off=3 value: 0 5 link-status: flags: enum enums: Good=0 Bad=1 value: 0 6 non-desktop: flags: immutable range values: 0 1 value: 0 4 TILE: flags: immutable blob blobs: value: 281 subconnector: flags: immutable enum enums: Unknown=0 VGA=1 DVI-D=3 HDMI=11 DP=10 Wireless=18 Native=15 value: 11 282 audio: flags: enum enums: force-dvi=18446744073709551614 off=18446744073709551615 auto=0 on=1 value: 0 283 Broadcast RGB: flags: enum enums: Automatic=0 Full=1 Limited 16:235=2 value: 0 306 max bpc: flags: range values: 6 12 value: 12 307 Colorspace: flags: enum enums: Default=0 RGB_Wide_Gamut_Fixed_Point=13 RGB_Wide_Gamut_Floating_Point=14 opRGB=7 DCI-P3_RGB_D65=11 BT2020_RGB=9 BT601_YCC=15 BT709_YCC=2 XVYCC_601=3 XVYCC_709=4 SYCC_601=5 opYCC_601=6 BT2020_CYCC=8 BT2020_YCC=10 value: 0 7 HDR_OUTPUT_METADATA: flags: blob blobs: value: 286 Content Protection: flags: enum enums: Undesired=0 Desired=1 Enabled=2 value: 0 Connector 309 (DP-4) 1 EDID: flags: immutable blob blobs: value: 2 DPMS: flags: enum enums: On=0 Standby=1 Suspend=2 Off=3 value: 3 5 link-status: flags: enum enums: Good=0 Bad=1 value: 0 6 non-desktop: flags: immutable range values: 0 1 value: 0 4 TILE: flags: immutable blob blobs: value: 281 subconnector: flags: immutable enum enums: Unknown=0 VGA=1 DVI-D=3 HDMI=11 DP=10 Wireless=18 Native=15 value: 0 282 audio: flags: enum enums: force-dvi=18446744073709551614 off=18446744073709551615 auto=0 on=1 value: 0 283 Broadcast RGB: flags: enum enums: Automatic=0 Full=1 Limited 16:235=2 value: 0 314 max bpc: flags: range values: 6 12 value: 12 315 Colorspace: flags: enum enums: Default=0 RGB_Wide_Gamut_Fixed_Point=13 RGB_Wide_Gamut_Floating_Point=14 opRGB=7 DCI-P3_RGB_D65=11 BT2020_RGB=9 BT601_YCC=15 BT709_YCC=2 XVYCC_601=3 XVYCC_709=4 SYCC_601=5 opYCC_601=6 BT2020_CYCC=8 BT2020_YCC=10 value: 0 7 HDR_OUTPUT_METADATA: flags: blob blobs: value: 286 Content Protection: flags: enum enums: Undesired=0 Desired=1 Enabled=2 value: 0 CRTC 91 24 VRR_ENABLED: flags: range values: 0 1 value: 0 25 DEGAMMA_LUT: flags: blob blobs: value: 26 DEGAMMA_LUT_SIZE: flags: immutable range values: 0 4294967295 value: 33 27 CTM: flags: blob blobs: value: 28 GAMMA_LUT: flags: blob blobs: value: 29 GAMMA_LUT_SIZE: flags: immutable range values: 0 4294967295 value: 262145 CRTC 152 24 VRR_ENABLED: flags: range values: 0 1 value: 0 25 DEGAMMA_LUT: flags: blob blobs: value: 26 DEGAMMA_LUT_SIZE: flags: immutable range values: 0 4294967295 value: 33 27 CTM: flags: blob blobs: value: 28 GAMMA_LUT: flags: blob blobs: value: 29 GAMMA_LUT_SIZE: flags: immutable range values: 0 4294967295 value: 262145 CRTC 213 24 VRR_ENABLED: flags: range values: 0 1 value: 0 25 DEGAMMA_LUT: flags: blob blobs: value: 26 DEGAMMA_LUT_SIZE: flags: immutable range values: 0 4294967295 value: 33 27 CTM: flags: blob blobs: value: 28 GAMMA_LUT: flags: blob blobs: value: 29 GAMMA_LUT_SIZE: flags: immutable range values: 0 4294967295 value: 262145 CRTC 274 24 VRR_ENABLED: flags: range values: 0 1 value: 0 25 DEGAMMA_LUT: flags: blob blobs: value: 26 DEGAMMA_LUT_SIZE: flags: immutable range values: 0 4294967295 value: 33 27 CTM: flags: blob blobs: value: 28 GAMMA_LUT: flags: blob blobs: value: 29 GAMMA_LUT_SIZE: flags: immutable range values: 0 4294967295 value: 262145
will you need to wait to see if they patch it in kernel?
I have no means to check why it does not work. It does look like PCON may be an issue, but it's all speculation at this point.
We need to wait for hardware with a native HDMI port to make any conclusions.
As soon as consumer Mini-ITX Tiger Lake boards are available I will buy one of those.
ok well this saves me wasting money on nuc11
wonder if its due to the new gfx chip on the i5 and i7s. maybe you need updated driver.
