Hi there.
I searched and could not find an addon that would allow me to connect from under Kodi to my remote computer on Windows.
Could you help me?
UPD. Generic х64, 8.2.5.
Hi there.
Could you help me?
"I searched and could not find" your hardware nor LE release - so we are equal.
Depending on your hardware, they "MAY" be a solution.
i'm sorry. Generic х64, 8.2.5.
There is a VNC server addon for LE allowing you to connect from PC to HTPC, but nothing exists that allows connecting from HTPC to PC.
Hi everyone, newbie question here.
I'm using the VNC addon and it works great. My LE is installed on a Raspberry PI 3. Now I need some help, how can I copy and paste (from PC to LE)?
You can't, because LE has no 'desktop' environment. Enable SSH and use an SFTP client (e.g. WinSFTP).
Thanks for your answer but that will not solve my problem. I just want an easy way to enter text, my APIs in an addon configuration for example in addon on LE.
Then use a Kodi remote, eg Kodi Remote, Kore, Sybu, etc.
