ON AMD Ryzen 5 2400G the Build works, Intel Gemeni Lake i will test later.
LE 9.0-devel for more Hardware (Gemini / Coffee / Cannon / Ice Lake, AMD Vega / Raven APU) and luks, lvm2, dm-raid
- sky42
- Thread is Unresolved
I still get a black screen on switching. If I set the Kodi gui to 30hz there is no problem. This only seems to happen on 1920x1080. There is also no problem if the Kodi gui is set to [email protected] .
Works o my Asrock J5005-ITX
Tested on NUC7PJYH connected to a Samsung LED TV over Yamaha AVR. No signal on every boot, I have to switch off/on the TV to get a picture.
After Kodi started, switching resolution seems to be ok so far.
Same (in my case) for my braswell and broadwell Nuc in combination with AVR
Someone on Kodi forum almost 18 months ago said that was an issue caused by AVR (onkyo or Denon) and I found other users with AVR and same issue (something about clock delay due AVR passthrough )
After many months of bad WAF (everytime a blackscreen =force reboot) i read on libreelec forum that a solution was to force gui to 30hz and now I found this thread with same issue and same solution works
So probably is the same bug ?
Same here with Onkyo 818, but since I have 4k TV my Kodi box is connected 2x HDMI so that 1x for audio to the Onkyo and 1x tv is used and I don't bother anymore.
But how do you switch ? for audio i use
btw i forgot to say that i found this bug also on rpi forum
BUG: Black screen when returning after watching in 23.976hz.
I get it to work on my old 1080p plasma but no image on my brand new 4k qled (QE65Q9FN )
Any log or something I should get out of the system as I get ssh acccess but no picture after the uefi boot screen?
No switching.
My HTPC has DP 1.2 and HDMI 1.4.
- DP 1.2 + Club 3D CAC-1070 = HDMI 2.0 connected to TV LG 55E6D
- HDMI 1.4 connected to Onkyo 818 just for Audio
In Kodi Video on DP1 and Audio on HDMI1
My 2nd old Haswell HTPC just for testing has 2x HDMI. Same setup. And the 3rd I a RPi2 also for testing, but that one is only to the Onkyo connected.
As remote control I use a Harmony Elite. For the Intel ones with Bluetooth and the raspi with a FLRC. I took me quite some time to set it up.
ah sorry i forgot to post what i use
software solution
Audio Profiles - Easy switch between different audio settings (that can also auto switch from avr mode to tv mode )
i toggle tv to avr via remote key mapping
so your avr is always on ? or you set action to harmony ?
Like: Tv series only audio tv..... avr switch standby
Like : film avr switch on
cause sometimes ago i also had coldboot problem a developer teach me to append to custom edid autostart also the resolution and refresh rate at autostart but i'm sorry i'm not able to tell you
so i have a string like that
BOOT_IMAGE=/KERNEL boot=LABEL=System disk=LABEL=Storage ssh quiet initrd=/edid.cpio drm_kms_helper.edid_firmware=HDMI-A-1:edid/edid.bin video=HDMI-A-1:[email protected]
btw i found also this bug with avr
Occasional Refresh Rate Change Problems
(but in my case i get only black screen not unsupported signal)
edid sorry for my ot
Sorry missed the update notification (again).
Is this with my #0612b build?
We're really not sure why some users (fortunately a very small number) don't get video after the UEFI boot screen. If you're able to connect to the Samba share, navigate to the Logfiles folder and try uploading the latest zip file to dropbox/googledrive/etc. and post the link. Inside are a number of logfiles, hopefully there might be a clue to what is happening. If you have two video outputs have you tried switching the video cable, it wouldn't be the first time an Intel box has started outputting video on one output only to switch it to the other output during boot.
milhouse Your build gets stuck at this point on my 2400g. (see picture here: Dropbox - 2018-06-11 10.11.09.jpg )
Is this still an issue for you? Googgling around it looks like the messages may be harmless, and the result of a poorly implemented BIOS.
Question #293489 : Questions : UbuntuBug #1553690 “Lenovo Y700-17ISK: ACPI Errors” : Bugs : linux package : Ubuntu
Bug 1556967 – ACPI Error: [SMIC] Namespace lookup failure, AE_ALREADY_EXISTS (20170831/dswload-378)
Check your ACPI BIOS settings, or see if there's a BIOS update available? -
AVR always on and sound of TV always off. I am nearly blind (viewing angel 4 degrees) and only use a video size of 50% (full size GUI), but I hear like a bat. So audio is 75% of the experience and i don't really care about power consumption. And because of that I invested a lot of money in my Nubert loudspeaker. It would be silly to not use them.
Check your ACPI BIOS settings, or see if there's a BIOS update available?It is build 0612b yes. Logfiles are here Dropbox - log-2018-06-14-12.02.58.zip
A new version 2 of the patch "NUC HDMI port issues" has been posted: [V2] drm/i915/glk: Add Quirk for GLK NUC HDMI port issues
Today i could test an AMD A12-9800E CPU, Full HD no problem, 4K no Hardware Acelleration,this CPU uses an R7 Graphic.
With my Ryzen 5 2400G till now it works.
