The problem is I got it running on old Libre 7.0.3 and I would like to stay on it At leat Kodi on my iPad is connecting with server with no hassle
.Net Core runtime and Emby
awiouy -
June 3, 2018 at 9:11 PM -
- Official Post
LibreELEC 7.0.3 is EOL. You are on your own.
Updating Emby will be limited by the version of Mono (4.2.1.102) shipped by LibreELEC 7.0.3.
You could try with Docker.
Hi.
First, thank you @awiouy for the effort.
I'm on LE9 on a rock64 (aarch64) device, and testing image.Unfortunatly, I think I'm missing the mono part.
Any chance to find it somewhere?
tools.dotnet-runtime reports
./le_dotnet: line 8: dotnet: not found
- Official Post
Hi.
You are missing dotnet-runtime (not Mono).
What is the output of ldd $(which dotnet)?
Thank you for taking the time.
which dotnet returns nothing. So ldd $(which dotnet) fails with ldd: $missing file arguments.
But since you're talking about dotnet-runtime, it's indeed in /storage/.kodi/addons/tools.dotnet-runtime/bin/dotnet-runtime-2.1.2
I guess it is the /storage/.kodi/addons/tools.dotnet-runtime/bin/dotnet script which fails.
Bash#!/bin/sh # SPDX-License-Identifier: GPL-2.0-or-later # Copyright (C) 2018-present Team LibreELEC (https://libreelec.tv) . /etc/profile oe_setup_addon tools.dotnet-runtime DOTNET_SYSTEM_GLOBALIZATION_INVARIANT="1" \ LD_LIBRARY_PATH="$ADDON_DIR/libs:$LD_LIBRARY_PATH" \ dotnet "$@"
$PATH doesn't include /storage/.kodi/addons/tools.dotnet-runtime/bin/dotnet-runtime-2.1.2
Code# echo $PATH /usr/bin:/usr/sbin:/storage/.kodi/addons/service.emby/bin:/storage/.kodi/addons/service.system.docker/bin:/storage/.kodi/addons/tools.dotnet-runtime/bin:/storage/.kodi/addons/tools.ffmpeg-tools/bin
And I can see /storage/.kodi/addons/tools.dotnet-runtime/bin/dotnet-runtime-2.1.2/dotnet doesn't have execution set either.
-rw-r--r-- 1 root root 76148 Sep 5 08:30 dotnet
A workaround is to soft link dotnet bin, and add execution. But I guess that's not the regular way.
- Official Post
And I can see /storage/.kodi/addons/tools.dotnet-runtime/bin/dotnet-runtime-2.1.2/dotnet doesn't have execution set either.[tt][tt][tt][/tt][/tt][/tt]
PATH includes /storage/.kodi/addons/tools.dotnet-runtime/bin
The question is now: is dotnet executable and if not, why?
Yes. /storage/.kodi/addons/tools.dotnet-runtime/bin is indeed in PATH
But /storage/.kodi/addons/tools.dotnet-runtime/bin/dotnet-runtime-2.1.2 doesn't.
So, le_dotnet script can't find dotnet executable.
Either add /dotnet-runtime-2.1.2 to le_dotnet script. Or add it to PATH
Or that's behond my linux knowledge.
And, no /storage/.kodi/addons/tools.dotnet-runtime/bin/dotnet-runtime-2.1.2/dotnet doesn't have execution permission by default when I installed addon.
- Official Post
hm...
No idea why dotnet ends up in dotnet-runtme-2.1.2, it should be in /storage/.kodi/addons/tools.dotnet-runtime/bin.
Move it there to fix you issue.
I did it with soft link.
Works pretty well once all in place.
Way better than docker did, before it broke completely.Thank you again.
Hi awiouy! Is it possible to use emby with dotnet on 8.2.5 generic ? Server has updated to 3.2.34.0 but I still couldn't connect with mono.
edit: Well it's working now with mono
Sorry awiouy! Just answer if dotnet can be used with 8.2.5 please
- Official Post
LibreELEC development has shifted from 8.2 to 9.0.
.Net Core Runtime and Emby could be backported to LibreELEC 8.2,5, but it would take me more time to do that (backport, build, test, etc.) than for you to upgrade to LibreELEC 9.0.
no worries. Thanks for reply 👍
It seems Emby Server Addon not working after updated recently.
Just checking if this is only me or anyone else experience this too?
- Official Post
No system information, no log (journalctl -u service.emby)
How do you expect anyone to help you?
Sorry for being not informative. I just saw above comments about .net issue and will try to correct the error.
Edited: As I saw the log that it's about dotnet error. So I tried soft link method as mentioned in above comments. And It's running ok now.
I will definitely provide log next time. Thanks.
- Official Post
Thank you for the feedback.
I will try to fix the issue in the next revision
Hi awiouy
Just after updating to Libre 9 and got this. All plugins updated and works except emby
Quote-- Logs begin at Thu 2018-09-27 22:19:34 IST, end at Thu 2018-09-27 22:27:00 IST. --
Sep 27 22:19:36 HTPC systemd[1]: Started Emby - streaming server.
Sep 27 22:19:37 HTPC sh[294]: /storage/.kodi/addons/tools.dotnet-runtime/bin/le_dotnet: line 8: dotnet: not found
Sep 27 22:19:37 HTPC systemd[1]: service.emby.service: Main process exited, code=exited, status=127/n/a
Sep 27 22:19:37 HTPC systemd[1]: service.emby.service: Failed with result 'exit-code'.
Sep 27 22:19:37 HTPC systemd[1]: service.emby.service: Service RestartSec=100ms expired, scheduling restart.
Sep 27 22:19:37 HTPC systemd[1]: service.emby.service: Scheduled restart job, restart counter is at 1.
Sep 27 22:19:37 HTPC systemd[1]: Stopped Emby - streaming server.
Sep 27 22:19:37 HTPC systemd[1]: Started Emby - streaming server.
Sep 27 22:19:37 HTPC sh[544]: /storage/.kodi/addons/tools.dotnet-runtime/bin/le_dotnet: line 8: dotnet: not found
Sep 27 22:19:37 HTPC systemd[1]: service.emby.service: Scheduled restart job, restart counter is at 2.
Sep 27 22:19:37 HTPC sh[582]: /storage/.kodi/addons/tools.dotnet-runtime/bin/le_dotnet: line 8: dotnet: not found
Sep 27 22:19:37 HTPC systemd[1]: service.emby.service: Scheduled restart job, restart counter is at 3.
Also there is no os.libreelec.tv installed in dependency list...
Any help please ?
