Reboot doesn't work
  • I am running 8.2.5 (upgraded from 8.2.4). I PXE boot and both my boot and root are served via nfs. I am using Confluence. When I select the reboot (not power down) the screen goes blank and never reboots. I cannot tell if it is actually powering off or just hung. It requires power cycle to recover. I am not certain, but I do not believe this happened with 8.2.4 but I could be wrong.
    Using ssh and 'reboot' command works fine.
    Below is journalctl -f before it either hangs or powers off.
    • Official Post
    I've a feeling this is just a timing issue. I'm just guessing... but as the system is shutting down the HDMI connection is lost and never recovers.
    If you can ping and ssh into the rebooted box - then it's an issue of NFS booting
