  • Quote from balbes150
    Try the latest version image 20191008. Preferably with UART output.
    Hello balbes150,
    Nanopi-K2 booting again.
    GXBB:BL1:08dafd:0a8993;FEAT:EDFC318C;POC:3;RCY:0;EMMC:800;NAND:81;SD:0;READ:0;CHK:0;
    no sdio debug board detected
    TE: 317760
    BL2 Built : 12:06:06, Jun 13 2016.
    gxb g176ecdb - laiyin.mo@droid12-sz
    set vcck to 1100 mv
    set vddee to 1000 mv
    Board ID = 8
    CPU clk: 1536MHz
    DDR chl: Rank0+1 same @ 792MHz
    DDR0: 2048MB(auto)-2T-11
    DataBus test pass!
    AddrBus test pass!
    Load fip header from SD, src: 0x0000c200, des: 0x01400000, size: 0x00004000
    New fip structure!
    Load bl30 from SD, src: 0x00010200, des: 0x01000000, size: 0x0000d460
    Sending bl30......................................................OK.
    Run bl30...
    Load bl31 from SD, src: 0x00020200, des: 0x101000[00, size: 0x00013140
    Image: gxb_v1.1.3134-b387442 2016-06-16 14:48:44 yun.cai@droid06]
    OPS=0x13
    f0 8c d5 21 23 9f ab d1 5e e4 dd 45 [0.413206 Inits done]
    secure task start!
    high task start!
    low task start!
    Load bl33 from SD, src: 0x00034200, des: 0x01000000, size: 0x0007c300
    NOTICE: BL3-1: v1.0(debug):c813a61
    NOTICE: BL3-1: Built : 14:47:05, Jun 16 2016
    INFO: BL3-1: Initializing runtime services
    WARNING: No OPTEE provided by BL2 boot loader
    ERROR: Error initializing runtime service opteed_fast
    INFO: BL3-1: Preparing for EL3 exit to normal world
    INFO: BL3-1: Next image address = 0x1000000
    INFO: BL3-1: Next image spsr = 0x3c9
    U-Boot 2019.07 (Oct 08 2019 - 15:37:28 +0300) nanopi-k2
    Model: Unknown
    Soc: Amlogic Meson GXBB (S905) Revision 1f:c (13:1)
    DRAM: 2 GiB
    MMC: mmc@70000: 0, mmc@72000: 1
    In: serial@4c0
    Out: serial@4c0
    Err: serial@4c0
    Net:
    Warning: ethernet@c9410000 (eth0) using random MAC address - 42:a2:51:d6:ad:8a
    eth0: ethernet@c9410000
    Hit any key to stop autoboot: 0
    switch to partitions #0, OK
    mmc1 is current device
    Scanning mmc 1:1...
    Found /extlinux/extlinux.conf
    Retrieving file: /extlinux/extlinux.conf
    161 bytes read in 5 ms (31.3 KiB/s)
    1: LibreELEC
    Retrieving file: /KERNEL
    17723400 bytes read in 856 ms (19.7 MiB/s)
    append: boot=LABEL=LIBREELEC disk=LABEL=STORAGE quiet console=ttyAML0,115200n8 console=tty0
    Retrieving file: /dtb/meson-gxbb-nanopi-k2.dtb
    27379 bytes read in 6 ms (4.4 MiB/s)
    ## Flattened Device Tree blob at 08008000
    Booting using the fdt blob at 0x8008000
    Loading Device Tree to 000000007df58000, end 000000007df61af2 ... OK
    Starting kernel ...
    [ 0.146241] debugfs: Directory 'c1105400.audio' with parent 'regmap' already present!
  • Can someone tell me whats the current situation with libreelec on n2? Does everything, except netflix, work?
    This topic is for images in development!
    If you want to test and tell yourself the current situation this is the right place.
    Here we help developers by reporting issues.
    Look for nothing stable here, just developing images as quoted in the topic.:thumbup:
  • balbes150 I realized did a unification of the amlogic images, I correct if I'm wrong.
    S905, X, D processors. Now use the same image. (Great job)
    CEC is broken in the images:
    AML.arm-9.80-devel-20191013180457-6e9040d-amlgx
    CvH I do not know if you have done some work on the crazycat driver until the moment did not recognize the tuner TBS.
    Edited once, last by erbas (October 13, 2019 at 8:32 PM).
  • I just tried the 0922 and 0944 for the s912. Unfortunately, the LibreElec Repository does not work, its pointing to an non-existing folder. Are there alternatives to get a PVR client except from the repository?
  • 1. The G12 platform (s905x2 s922x a311d) now uses a single image (it also works on N2).
    2. For the Odroid N2 model, I only check the option to run on USB media using SPIboot.
    3. Addons are transferred to the new Kodi-19 platform, there may be failures and not correct operation. Therefore, it is recommended to test a clean install\run (without using the update via TAR).
    Image update 20191019.
