Test LE images with Kodi-19 for S9xxx
  • Feedback for Minix U9 S912 box:
    so far no issues, tested playback for local MKVs (x264 720/1080p).
    Minix U9
    Zidoo X7
    Bqeel MVR9
    Edited once, last by muya ().
  • can nobody tell me how to get pvr.dvbviewer running?
    Two options:
    1. You can repeat this questions so much times untils some one tells You how to run it
    2. You can use a stable LE version and install addon from the repo
  • and ???
    which is stable?
    no stable exist!
    this version is the first candidate which can be called as stable. :P
    but without dvbviewer not usable for me.
  • l8 stable ... maybe, but its pvr.dvbviewer is not stable.
    i switch on german "deluxe music sd" and then i just scroll through the channels in mini epg ... freeze, crash, reboot.
  • @balbes:
    any changelog for your updates or not noticeable and just master ones?
    Minix U9
    Zidoo X7
    Bqeel MVR9
    Edited 4 times, last by muya ().
  • wedok Kodi bumped the addon api recently but we (me) didn't build/push updated 3.14 kernel addons to the repo since then so whats in the repo is probably not compatible. I'll update them in the next couple of days when I have time.
  • Updated image 20180511 (in catalog 20180511_1).
    The main change in the composition of the image added a data_to_emmc_uEnv.ini. Which allows the use of LE in the mode with the placement of the system on external media, and the data in the eMMC. Details of how this works can be found in this thread.
    [HOWTO] Boot from SD card, use internal memory for data
    Please note that to use the system in EMMC mode, you only need to rename the script on the media (SD card or USB flash drive) from
    to
    uEnv.ini
    You do not need to perform other steps. Not in itself a eMMC not need to change.
    Please note, uEnv.ini is a plain text file that contains the variables to run the kernel. You can easily add or remove variables. For example, you can add a variable with its MAC address mac=you_Mac_address
  • balbes150
    Changed the title of the thread from “Test LibreELEC images with KODI-18 for S9xxx.” to “Test LibreELEC images with KODI-18 for S9xxx”.
  • Downloaded the S912 build for my U9. Playback seems fine but I have found I am not getting any sound output for AAC-LC (LATM) encoded video. AC3 files work fine but I just get silence on those AAC tracks. I could play other AAC files fine, just those originating from DVB recordings.
    Played these in a windows nightly from yesterday and they play so it seems to be isolated to my device/build. Anyone else seeing this?
  • I'm struggling getting the Netflix Add-On working on my Minix UH-9 with CoreELEC. Is it worth trying to update with LibreELEC-S905.arm-18.0_20180522.tar?
  • great!!!
    I have a box S905D p230 2G/8G, I had try LE8.0 and LE8.2.3 and LE8.9 all dont work,can not startup.
    and then use yours Armbian 5.4.4 mate 20180523, I could start whth "meson-gxl-s905d-p230.dtb",but when into startx have a error Tip, in left up coner just have firefox , not more, so could not do anything,and cannot shutdown reboot. i can play desktop test.mp4 and test1.mp4 . too slow graphy.
    at time,I find this ,yours LE
    I just download your LE, hope fun
    sorry for my poor english
    can you tell me how can i boot LE8.2 use which dtb file ?
    great!!!
