Audio dropouts on HDMI - SPDIF not affected
    I'm running LibreELEC on a Wetek Play 2. I'm connected to my TV via HDMI, and I'm using the SPDIF output to my amplifier.
    I'm not sure if this is a Wetek issue or a LibreELEC, I've pasted my log (
    External Content pastebin.com
    ) which was generated after one of the audio drops.
    I've noticed for some time either when playing a video, playing music or streaming internet radio, that the audio drops out, and it seems random. The picture is unaffected.
    When playing through my amplifier via optical cable, I've not had the dropouts. I've changed HDMI cable and HDMI inputs with no change.
    I would appreciate if anyone could suggest something as it is quite annoying and frustrating, and I'm at a loss.
    Dozer.
  • You enabled debug logging after you selected the file to play.
    To provide a debuglog, please enable debug logging, reboot and then reproduce your issue. don´t turn debugging of as long as it takes to reproduce the issue.
    Unfortunately that´s not helpful.
