Hello guys,
i have a Sunvell t95z Plus with 3/32Gb and a few problems with it.
I have installed the following on a microSD Card:
LibreELEC-S912.arm-8.90.5.img.gz
gxm_q200_3g_t95z.dtb
The problems are:
1. Gbit ethernet is not working properly. Connection is etablished but no traffic goes over the line.
2. The display in the front is not working.
-> Fixed DTB in post #3. Thanks to The Coolest
My actually workarounds are:
1. Connect the Box over Wifi with the LAN. Connect over SSH into the sweet little box and
this sets the network to 100Mbit which works.
I tried to install the fd628 addon, the display dont work
I also tried some fd628 dev builds, also not working
/proc/device-tree/fd628_dev/ is present
I have generated a keymap file for the t95z remote control. See Attachment
Its strange that the 1Gbit Connection is so faulty.
I hope someone other have this box and can help.
In ARMbian and ARCHlinux the same problems with the ethernet.
Cheers
derBG
