LE9.0 remote configs ir-keytable Amlogic devices
  • thanks, I know it is stupid question but I m simple user. How to create rc_maps.cfg?
    Do you use samba or SSH ?
    If using samba, just create a text file in the appropriate folder with a right click and edit with your prefered editor.
    if using ssh, type this command:
    1. echo "meson-ir   *  a95x.txt" > /storage/.config/rc_maps.cfg
  • Do you use samba or SSH ?
    I did not work in samba or ssh, I will try today. Thanks you very much for ur kind explanation.
  • Here are mine. I have to add that I use both (also) for my MiniMXII III box.
    I will update this post when all works the way I want to. The file works for both remotes without any re-adjustment.
    I have remapped and added the necessary files. In the end I didn't miss the possibility to "longpress".
    Images
    Files
    • MiniMX.zip
      (5.13 kB, downloaded 916 times, last: )
    Beelink MiniMXIII II 2GB, 32GB always running latest Libreelec from SD card. No issues so far(except for the ones already known or posted by me).
    Mecool m8s Pro+ which with widevine level 1, Android runs a hacked version of android TV.
    Edited 2 times, last by Gregoir3: Added my other remote and re-uploaded a updated file. From Coreelec 8.9.01 onwards use keyboard.xml.(not remote.xml) I will update this later. ().
  • This pointed me into the right direction. Unfortunately I have not figured out (yet) how to use <mod="longpress"> which would add a lot more functionality.
  • One suggesting
    Can you keep remote list on first topic?
    Its easily to users to find their remote instead to keep always asking for remote file
    - Box Android Mini M8S II (Amlogic S905X, 2GB RAM, 8GB ROM)
    - Ugreen USB Ethernet Adapter Usb 3.0 2.0 [ASIX AX88179 Chipset]
    - LibreELEC 8.2 (Nougat Kernel) builds aimed at devices based on Amlogic S905/S905X SoC.
    Longpress in kodi only works for keyboards, not remotes that reach kodi as lirc events.
    You can disable the Linux event -> lirc event translation, eg by creating an empty eventlircd udev rule:
    1. : > /storage/.config/udev.rules.d/98-eventlircd.rules
    then the remote buttons/keys reach kodi like standard keyboard input.
    There's one drawback though: kodi currently can't deal with a lot of keycodes used on remotes, eg KEY_OK, KEY_CHANNELUP/DOWN and a bunch of others won't work. So you'll have to use different keycodes in your keymap (eg KEY_ENTER instead of KEY_OK).
  • One suggesting
    Good, idea, to have a list that anyone can update, & perhaps a repo? so anyone can upload remote files. Rather than one person having to maintain it.
    Synology DS414 Plex Pass
  • HiassofT, Is there any example of usage? What files to modify in this case for longpress actions?
  • Guys, what would be the best way to configure both a NEC and an RC-6 remote ?
    I have been reading and trying without any luck.
    Is it even possibe to have both an rc-6 and a nec driven remote activated at the same time?
    Thanks for any pointers.
  • Yes, that's possible - and default LibreELEC configuration uses that to support both rc-6 remotes like MCE and NEC remotes like Xbox 360, One (crap, I always mix these up) Wetek Hub etc out of the box.
    All that's needed is that you put both RC6 and NEC into the header, after "type:". See for example the /usr/lib/udev/rc_keymaps/libreelec_multi_amlogic file:
    1. # table libreelec_multi_amlogic, type: RC6 NEC
    2. # rc6_mce
    3. 0x800f0400 KEY_NUMERIC_0
    4. ...
    5. # wetek_hub
    6. 0x77f1 KEY_POWER
    7. 0x77f2 KEY_HOME
    So, simply create a separate keymap for each remote and then combine the content into a "multi" keymap file and use a header like above.
  • I don't know, but could you add the extra remote to the /storage/.config/rc_keymaps.
    then edit
    /storage/.config/rc_maps.cfg to add the other remote as well?
    looks like someone has given a better answer,
  • Ah, the keymap combining part is where i got stuck.
    Created a seperate keymap file for the rc-6 Xbox 360 remote and it works, but only for a single remote at a time.
    Thanks for your kind explanation, saved me some time :-)
  • BTW: before you start creating a keymap on your own have a look what's already shipping with LE in /usr/lib/udev/rc_keymaps.
    Xbox 360 and Xbox One are already there, so you can just put the name in rc_maps.cfg and don't need to create an rc_keymaps/MYREMOTE file first. Or you can use these as a template in case you want to modify something.
  • haha yes, i noticed that while browsing the dir. you pointed me too.
    Excellent, both working now. I really like how you can just grab some remote you like now and hook it up without much effort.
