I'm not sure, because Android also crashes/freezes and without you u-boot CE/LE/Android not. Has nothing to do with CE/LE or Android i think. Maybe a small piece in u-boot, wrong memory addressing or something.
Remote power trouble
tyrol_gangster -
January 24, 2018 at 8:54 PM -
Thank you for your reply.
I have fixed the bug. You do not have to disable the CEC driver
Download (for LPDDR3 Devices)
Does it work in the h96 pro+ revision wisdom? I suffer from this problem
Please make some photos of the PCB, memory type (ddr3, ddr4 or lpddr3) is crucial
Edit: You have DDR3-
1600..? I'll post it late at night. -
...Maybe a small piece in u-boot, wrong memory addressing or something.
All devices with LPDDR3 work without problems with this u-boot, except yours. Mine runs day and night. Nobody has any trouble with his box until now.
At the memory addressing nothing was changed.
mega-samu
not testedOk, thanks. This weekend I'm trying, I'm examining.
I leave the photos of the box and I am sorry for not being able to send them to you before.
Which uboot should i use
i would like to retain alteast the ram speed that the stock uboot uses
H96 PRO+ 3GB 32GB
PCB CZ-S32-v2.2 20161012(A15)
QL 1730
JOB20170808 3+32/9377
1 x amlogic S912 OCTA-CORE BODGHN01404 J-TNA346.00
1 x 32GB Toshiba 19nm THGBMBG8D4KBAIR 170821AE EMMC HS400 V5.0 Read 270MB Write 90MB
1 x Fn-Link 8223A-SR COB009 1732 (QCA9377 433Mbps 1T1R 802.11a/b/g/n/ac BTLE 4.1)
1 x RTL8211F H6120H4 GH25 Gigabit Ethernet Transceiver
1 x GL850G HH4JB05Y22 713SGF9891 Genesys Logic 4 Port USB 2.0 Hub
2 x 1GB SpecTek 512X16DDR3 HL - FC4F 1708 / DY6L 1704 (SpecTek State 1600MHZ DDR3 1.5v) (rebadged Micron 512x16 DDR3L 1866 CL13)
2 x 512MB Micron 6EN77 D9SDD 3ZRJ (256X16 DDR3L 1866 CL13) D9SDD full PN=MT41K256M16LY-107:N
then i need a log from stock u-boot
is there any way to get that without serial access as i dont have a serial cable
No.
Please test the u-boot@912Mhz_DDR3. I doubt that your stock uboot runs over the 1000..Mhz range
No.
ok will make an image now with the amlogic customization tool
is that 912mhz/1824ddr
or
406mhz/912mhz ddr
or
406mhz/912mhz ddr
Both memory variants run at 912Mhz
Sorry im not explaining it right
PC3-12800 Runs at 800mhz which is 1600 DDR
is the 912mhz the actual mhz e.g. 1824 DDR
It bricked btw flashing 912
flashing my stock bootloader back now via sd card
That's why I need log from Serial console
I pulled the 792mhz bootloader.PARTITION from S912_H96_3G_DDR34_171120_MAC_ubootfix
and im flashing it now combined in aml_7.1.2_s912_q9377-S912_mac-20180409
ok it worked
and its powering on and off from the remote in le 8.2.2.3 kszaq build
can i get a link to your latest ddr3 uboot @ 792
just incase the one in S912_H96_3G_DDR34_171120_MAC_ubootfix
is an old build with problems
Supported DDR3 CLK Range:
7-7-7: 375 ~ 533mhz
9-9-9: 533 ~ 667mhz
11-11-11: 667 ~ 800mhz
12-12-12: 800 ~ 933mhz
13-13-13: 933 ~ 1066mhz
