[SOLVED] Dropped frames caused by subtitle rendering
  • bit4freak The issue was not resolved in Krypton and will probably never be. Kodi developers no longer update Krypton and I doubt any of us has knowledge to backport huge Leia changes.
    No one expects fixes in Krypton. Bad news it's still in Leia. It occurs less frequently but it's still there.
    The 2 of my samples and logs are coming from newest Leia build.
    TX5 PRO S905X
  • Your issue has nothing to do with subtitles rendering. Subtitle rendering issue was identified in S912 caused by libhybris emulator.
    In first LOG is no skips, perfect playback, most of frames prepared for rendering 80 ms (2 frames ahead). Render loop, only time critical thread, is fast enough ( 5-10ms) and most of frame time (41ms) is waiting in poll-frame. In second LOG2 are 6 frame skips after ~500ms lost of playback control. Probably another background task heavy loads CPUs. You can try to enable all component specific debugging to see offender.
  • Your issue has nothing to do with subtitles rendering. In second LOG2 are 6 frame skips after ~500ms lost of playback control.
    In the second log I've played the file couple of times so it's messy.
    I will make a third log, this time using the first sample from Star Trek and will enable all components.
    Something causes these stutters because exactly the same samples or any other video files without subs are playing like a charm.
    OK. Two logs again using this sample
    LOG1: there was 1 visible stutter - Ubuntu Pastebin
    LOG2: sample played stutter free - Ubuntu Pastebin
    Maybe there will be some differences between the two that will allow to identify the issue.
    Last build that was free from this was kszaqs Jarvis-7.0.3.012l
    TX5 PRO S905X
  • No one expects fixes in Krypton. Bad news it's still in Leia. It occurs less frequently but it's still there.
    I feel for you bro, but I really don't encounter subtitle stuttering on our S905X boxes. 99 percent of the movies we watch have external .srt and it plays fine. I don't have S912 to test.
  • I feel for you bro, but I really don't encounter subtitle stuttering on our S905X boxes. 99 percent of the movies we watch have external .srt and it plays fine. I don't have S912 to test.
    frequenzy, what is your subtitles settings (font, size, Colours etc)?
  • I really don't encounter subtitle stuttering on our S905X boxes. 99 percent of the movies we watch have external .srt and it plays fine.
    Confirm - 100% of my english videos have external(.srt) subtitles and playing fine on my S905X boxes - last video watched yesterday
    I have a S912 running LE 8.2 - will do some tests later - S912 is currently rarely used
  • Confirm - 100% of my english videos have external(.srt) subtitles and playing fine on my S905X boxes - last video watched yesterday
    Tim_Taylor, I also encounter minor stuttering in beginning of the movie (only first line of the subtitles) in my nexbox S905X but after that no stuttering visible. Kindly mention your subtitles font, size and colour?
  • Subtitle font, color and size = default
    that’s main the reason, because of default setting there is no stuttering. If someone mess with subtitles settings in krpton then subtitles stuttering appears.
  • that’s main the reason, because of default setting there is no stuttering. If someone mess with subtitles settings in krpton then subtitles stuttering appears.
    Why should i change subtitle settings ?
  • Dead end here - krypton is final
    Option: configure subtitle settings to default until kodi developer fixed it in leia
  • Only for explaining S912 subtitles issue. Letter rendering cost relatively lot of time. Rendered letters are cached and next rendering is then fast. Typically stuttering can appear at the begin of movie or at font changes ( italics).
  • Typically stuttering can appear at the begin of movie or at font changes (italics).
    And this is exactly where stutterings appear. With the difference that it's not only on S912 but S905X too.
    Tested with default subtitles settings and the problem persists.
    Some of you won't notice it at all. I've found only couple of files where it can be seen. Other videos play OK and even when there are stutters they are unnoticeable during watching.
    Hope it will be fixed in final Leia build.
    TX5 PRO S905X
  • Some of you won't notice it at all. I've found only couple of files where it can be seen.
    You are very, very sensitive.
    A friend of mine is like You - his eyes are better than an electron microskope :)
  • You are very, very sensitive.
    Yes, I am aware of my disroder :) My brain just can't stand any imperfections in some matters :)
    TX5 PRO S905X
  • My brain just can't stand any imperfections in some matters :)
    You need another hardware - amlogic is just another word for imperfection <X
