It should not matter but did you try set different refresh rate in System settings -> Display? By default it is 60 Hz for my setup. I've changed it to 50 Hz.
[SOLVED] Dropped frames caused by subtitle rendering
avirex -
November 20, 2017 at 7:38 PM -
There is no subtitle stutters with enabled playerdebug (ctrl+shift+o)
Maybe its a hint to fix this? Tested with 8.90.5
Also on my S912 box, no stutter with Playerdebug overlay on, with 8.90.4 and 8.2.2.3
Is there is any chance to fix this issue now after discovering playerdebug behaviour?
This is known a long time.
No, there is no chance to fix it in every special case.
I´m lucky - my hardware has no issue
Display More
I have a big problem with subtitles stutters with kszaq 8.2.2.3 and wrxtasy chroma 422 with enabled new features and 8.90.5
Look at this video Libreelec subtitles stutters - YouTube
Without amcodec acceleration everything is OK! but cpu is to slow for software 4k decoding
I`m using
echo '422,10bit' > /sys/class/amhdmitx/amhdmitx0/attr
echo 0 > /sys/module/di/parameters/nr2_en
echo 1 > /sys/module/di/parameters/bypass_all
Player > Video >
Adjust display refresh rate > Start/stop
Sync Playback to Display > Off
Hi Pinki, this is the exact same issue i'm having, a stutter in panning scenes at the moment (or just before) the subitle appears. Good thing you uploaded a YouTube video, that's probably better then explaining it in text.
Also, I'm not using the adjustments in the attr, nr2_en and bypass_all files you mentioned (using the echo commands). My player/video settings are the same though.
I tried it just to be sure but it makes no difference (i also tried 24 and 23.98 rates). Afaik when using the 'adjust refresh rate on start/stop' option, it does not matter what the refresh rate is of the Kodi interface as it will change according to the content which is being played (hence the option).
I can assure you this is not hardware related and your box does have this issue. You just don't see it
I'm sorry but that's the truth. Most users are happy they can use LibreELEC and they don't see any stuttering because this is not relevant to them.
Users with more sensitive eye, you just have to accept it.
How is it "hardware issue" when it does not exist without hw acceleration? Looks more like a video driver issue to me.
Hardware issue based on hardware acceleration and TV panel(hardware) - no LE developer is able to write a new amlogic hardware decoding driver until yet
Its possible to display subtitles without stuttering (playerdebug overlay)
Maybe someone can add "invisible overlay" like playerdebug as workaround to fix this?
I`ve found interesting thing. Video stutters only in some movies, whats the difference between them?
It looks like the problem is only with UTF8 subtitles internal/external srt? with internal PGS its OK. tested with 8 movies.
Example of stutering subtitle in attachment
I converted srt file from attachment to PGS (.sup) with GOSUP and then used MKVToolNix to merge PGS subtitles with mkv and now its working without stuttering!
Stuttering:
Text #2
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 2 h 1 min
Bit rate : 33 b/s
Count of elements : 1008
Stream size : 29.5 KiB (0%)
Title : Forced
Language : Polish
Default : Yes
Forced : Yes
Display MoreGeneral Unique ID : 195460561866350095351137015152747655368 (0x930C55BC4D666F23972DDBB781DAB0C8) Complete name : D:\Media\4K\2.mkv Format : Matroska Format version : Version 4 / Version 2 File size : 27.1 GiB Duration : 2 h 7 min Overall bit rate mode : Variable Overall bit rate : 30.3 Mb/s Encoded date : UTC 2017-06-18 00:05:24 Writing application : mkvmerge v10.0.0 ('To Drown In You') 64bit Writing library : libebml v1.3.4 + libmatroska v1.4.5 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main [email protected]@High Codec ID : V_MPEGH/ISO/HEVC Duration : 2 h 7 min Bit rate : 25.0 Mb/s Width : 3 840 pixels Height : 1 504 pixels Display aspect ratio : 2.553 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.181 Stream size : 22.4 GiB (82%) Writing library : x265 2.4+28-f850cdbe381c:[Windows][GCC 5.3.1][64 bit] 10bit Encoding settings : cpuid=1173503 / frame-threads=5 / numa-pools=20 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x1504 / interlace=0 / total-frames=184037 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=4 / no-allow-non-conformance / repeat-headers / annexb / aud / hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=1 / keyint=24 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=4 / scenecut=40 / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-src-pics / deblock=-2:-2 / no-sao / no-sao-non-deblock / rd=4 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / analysis-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=17.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=160000 / vbv-bufsize=160000 / vbv-init=0.9 / crf-max=0.0 / crf-min=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,0) / max-cll=1000,640 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / hdr / hdr-opt / no-dhdr10-opt / refine-level=5 / no-limit-sao / ctu-info=0 Default : Yes Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : SMPTE ST 2084 Matrix coefficients : BT.2020 non-constant Mastering display color pri : R: x=0.680000 y=0.320000, G: x=0.265000 y=0.690000, B: x=0.150000 y=0.060000, White point: x=0.312700 y=0.329000 Mastering display luminance : min: 0.0000 cd/m2, max: 1000.0000 cd/m2 Maximum Content Light Level : 1000 cd/m2 Maximum Frame-Average Light : 640 cd/m2 Audio #1 ID : 2 Format : TrueHD Format profile : TrueHD+Atmos / TrueHD Codec ID : A_TRUEHD Duration : 2 h 7 min Bit rate mode : Variable Bit rate : 3 737 kb/s Maximum bit rate : 7 230 kb/s Channel(s) : Object Based / 8 channels Channel positions : Object Based / Front: L C R, Side: L R, Back: L R, LFE Sampling rate : / 48.0 kHz Frame rate : 1 200.000 FPS (40 spf) Compression mode : Lossless Stream size : 3.34 GiB (12%) Language : English Default : No Forced : No Audio #2 ID : 4 Format : DTS Format/Info : Digital Theater Systems Mode : 16 Format settings, Endianness : Big Codec ID : A_DTS Duration : 2 h 7 min Bit rate mode : Constant Bit rate : 1 509 kb/s Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 spf) Bit depth : 24 bits Compression mode : Lossy Stream size : 1.35 GiB (5%) Language : Polish Default : Yes Forced : No Text #1 ID : 3 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 1 h 59 min Bit rate : 15.4 kb/s Count of elements : 2408 Stream size : 13.1 MiB (0%) Language : English Default : No Forced : No Text #2 ID : 5 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 2 h 1 min Bit rate : 33 b/s Count of elements : 1008 Stream size : 29.5 KiB (0%) Title : Forced Language : Polish Default : Yes Forced : Yes Text #3 ID : 6 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 1 h 39 min Bit rate : 8 b/s Count of elements : 224 Stream size : 5.90 KiB (0%) Language : Polish Default : No Forced : No Menu 00:00:00.000 : en:0:00:00.000 00:07:06.926 : en:0:07:06.926 00:17:30.883 : en:0:17:30.883 00:26:05.855 : en:0:26:05.855 00:31:14.038 : en:0:31:14.038 00:39:29.075 : en:0:39:29.075 00:46:17.566 : en:0:46:17.566 00:52:11.169 : en:0:52:11.169 00:58:50.360 : en:0:58:50.360 01:05:58.579 : en:1:05:58.579 01:13:01.293 : en:1:13:01.293 01:24:16.301 : en:1:24:16.301 01:31:50.880 : en:1:31:50.880 01:41:10.981 : en:1:41:10.981 01:46:07.611 : en:1:46:07.611 01:56:19.597 : en:1:56:19.597No stuttering:
Text #18
Format : PGS
Muxing mode : zlib
Duration : 2 h 6 min
Bit rate : 23.8 kb/s
Count of elements : 2970
Stream size : 21.6 MiB (0%)
Title : Polish-PGS
Language : Polish
Default : No
Forced : No
Display MoreGeneral Unique ID : 63670494676720079616558602284797410305 (0x2FE67DC110939A6DDD334E78F0123C01) Complete name : D:\Media\4K\1.mkv Format : Matroska Format version : Version 4 / Version 2 File size : 75.0 GiB Duration : 2 h 7 min Overall bit rate mode : Variable Overall bit rate : 84.2 Mb/s Movie name : 1 Encoded date : UTC 2018-01-17 11:14:11 Writing application : mkvmerge v20.0.0 ('I Am The Sun') 64-bit Writing library : libebml v1.3.5 + libmatroska v1.4.8 Cover : Yes Attachments : small_cover_land.jpg / cover.jpg / cover_land.jpg / small_cover.jpg Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main [email protected]@High Codec ID : V_MPEGH/ISO/HEVC Duration : 2 h 7 min Bit rate : 61.7 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.310 Stream size : 55.0 GiB (73%) Title : 1 Default : Yes Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : SMPTE ST 2084 Matrix coefficients : BT.2020 non-constant Mastering display color pri : R: x=0.680000 y=0.320000, G: x=0.265000 y=0.690000, B: x=0.150000 y=0.060000, White point: x=0.312700 y=0.329000 Mastering display luminance : min: 0.0050 cd/m2, max: 4000.0000 cd/m2 Audio #1 ID : 2 Format : TrueHD Format profile : TrueHD+Atmos / TrueHD Codec ID : A_TRUEHD Duration : 2 h 7 min Bit rate mode : Variable Bit rate : 5 484 kb/s Maximum bit rate : 8 955 kb/s Channel(s) : Object Based / 8 channels Channel positions : Object Based / Front: L C R, Side: L R, Back: L R, LFE Sampling rate : / 48.0 kHz Frame rate : 1 200.000 FPS (40 spf) Compression mode : Lossless Stream size : 4.89 GiB (7%) Title : 1 Language : English Default : Yes Forced : No Text #1 ID : 21 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 29.8 kb/s Count of elements : 3180 Stream size : 27.1 MiB (0%) Title : English-PGS Language : English Default : Yes Forced : No Text #2 ID : 22 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 23.5 kb/s Count of elements : 2858 Stream size : 21.3 MiB (0%) Title : French-PGS Language : French Default : No Forced : No Text #3 ID : 23 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 34.9 kb/s Count of elements : 3216 Stream size : 31.7 MiB (0%) Title : German-PGS Language : German Default : No Forced : No Text #6 ID : 26 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 23.9 kb/s Count of elements : 3008 Stream size : 21.7 MiB (0%) Title : Dutch-PGS Language : Dutch Default : No Forced : No Text #7 ID : 27 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 24.3 kb/s Count of elements : 3046 Stream size : 22.1 MiB (0%) Title : Chinese-PGS Language : Chinese Default : No Forced : No Text #8 ID : 28 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 23.9 kb/s Count of elements : 3032 Stream size : 21.7 MiB (0%) Title : Chinese-PGS Language : Chinese Default : No Forced : No Text #9 ID : 29 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 19.0 kb/s Count of elements : 3012 Stream size : 17.2 MiB (0%) Title : Korean-PGS Language : Korean Default : No Forced : No Text #10 ID : 30 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 28.5 kb/s Count of elements : 3030 Stream size : 25.9 MiB (0%) Title : Spanish-PGS Language : Spanish Default : No Forced : No Text #11 ID : 31 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 27.5 kb/s Count of elements : 3006 Stream size : 25.0 MiB (0%) Title : Portuguese-PGS Language : Portuguese Default : No Forced : No Text #12 ID : 32 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 13.6 kb/s Count of elements : 3024 Stream size : 12.4 MiB (0%) Title : Arabic-PGS Language : Arabic Default : No Forced : No Text #13 ID : 33 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 22.1 kb/s Count of elements : 3016 Stream size : 20.0 MiB (0%) Title : Czech-PGS Language : Czech Default : No Forced : No Text #14 ID : 34 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 24.4 kb/s Count of elements : 3026 Stream size : 22.1 MiB (0%) Title : Danish-PGS Language : Danish Default : No Forced : No Text #15 ID : 35 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 24.1 kb/s Count of elements : 2952 Stream size : 21.9 MiB (0%) Title : Finnish-PGS Language : Finnish Default : No Forced : No Text #16 ID : 36 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 21.0 kb/s Count of elements : 3026 Stream size : 19.1 MiB (0%) Title : Hebrew-PGS Language : Hebrew Default : No Forced : No Text #17 ID : 37 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 24.5 kb/s Count of elements : 2996 Stream size : 22.2 MiB (0%) Title : Norwegian-PGS Language : Norwegian Default : No Forced : No Text #18 ID : 38 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 23.8 kb/s Count of elements : 2970 Stream size : 21.6 MiB (0%) Title : Polish-PGS Language : Polish Default : No Forced : No Text #19 ID : 39 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 29.2 kb/s Count of elements : 3030 Stream size : 26.5 MiB (0%) Title : Portuguese-PGS Language : Portuguese Default : No Forced : No Text #20 ID : 40 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 27.9 kb/s Count of elements : 3044 Stream size : 25.3 MiB (0%) Title : Russian-PGS Language : Russian Default : No Forced : No Text #21 ID : 41 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 25.8 kb/s Count of elements : 2910 Stream size : 23.4 MiB (0%) Title : Swedish-PGS Language : Swedish Default : No Forced : No Text #22 ID : 42 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 27.5 kb/s Count of elements : 3030 Stream size : 24.9 MiB (0%) Title : Turkish-PGS Language : Turkish Default : No Forced : No Text #23 ID : 43 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 27.2 kb/s Count of elements : 2986 Stream size : 24.7 MiB (0%) Title : Hungarian-PGS Language : Hungarian Default : No Forced : No Text #24 ID : 44 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 367 b/s Count of elements : 60 Stream size : 340 KiB (0%) Title : French-FORCED-PGS Language : French Default : No Forced : No Text #25 ID : 45 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 380 b/s Count of elements : 54 Stream size : 352 KiB (0%) Title : German-FORCED-PGS Language : German Default : No Forced : No Text #26 ID : 46 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 351 b/s Count of elements : 52 Stream size : 325 KiB (0%) Title : Italian-FORCED-PGS Language : Italian Default : No Forced : No Text #27 ID : 47 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 431 b/s Count of elements : 64 Stream size : 399 KiB (0%) Title : Spanish-FORCED-PGS Language : Spanish Default : No Forced : No Text #28 ID : 48 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 382 b/s Count of elements : 54 Stream size : 354 KiB (0%) Title : Spanish-FORCED-PGS Language : Spanish Default : No Forced : No Text #29 ID : 49 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 380 b/s Count of elements : 54 Stream size : 352 KiB (0%) Title : Portuguese-FORCED-PGS Language : Portuguese Default : No Forced : No Text #30 ID : 50 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 2 h 6 min Bit rate : 390 b/s Count of elements : 66 Stream size : 362 KiB (0%) Title : Czech-FORCED-PGS Language : Czech Default : No Forced : No Text #31 ID : 51 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 1 h 56 min Bit rate : 20.5 kb/s Count of elements : 2600 Stream size : 17.1 MiB (0%) Title : Japanese-PGS Language : Japanese Default : No Forced : No Text #32 ID : 52 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 54 min 7 s Bit rate : 142 b/s Count of elements : 10 Stream size : 56.4 KiB (0%) Title : Japanese-FORCED-PGS Language : Japanese Default : No Forced : No Menu 00:00:00.000 : en:Chapter 1 00:08:44.982 : en:Chapter 2 00:19:31.128 : en:Chapter 3 00:31:32.932 : en:Chapter 4 00:41:42.500 : en:Chapter 5 00:49:35.597 : en:Chapter 6 00:58:29.589 : en:Chapter 7 01:09:19.989 : en:Chapter 8 01:19:07.159 : en:Chapter 9 01:29:09.385 : en:Chapter 10 01:36:08.512 : en:Chapter 11 01:43:26.575 : en:Chapter 12 01:52:58.772 : en:Chapter 13 01:57:59.489 : en:Chapter 14 -
If someone does not see the problem with subtitles, please check this files (20MB mkv) and give us know if it's now visible on s912 with HW decoding
Thx. for the sample Pinki
I can now clearly seen video frame upsets happening about every 1 second with the external subtitles when played on the U9 (S912) using Hardware video decoding.
However my S905 ODROID C2 does not have any problems whatsoever nor does a MECOOL S905X box, both running LE 8.2.x and using HW decoding.
It appears only S912's that are using the Hybrid Android/Linux GPU drivers are having such subtitle, video frame upset issues.
Subtitle rendering is a GPU function.We really need better optimised S912 Linux GPU video drivers to fix this LE S912 problem.
EDIT - good news S912 owners !
I've updated the kszaq modded Hybrid GPU drivers for the S912 and added an important VSync Hardkernel ODROID C2 patch:
I see no S912 Subtitle / video frame problems now playing the above test clip when using this LE 8.2.4 Kodi Krypton release:
LibreELEC-S912.arm-8.2.4-S912-Subtitles-fix.tar
The Kodi user interface seems snappier now as well.
W.
Great news.
Will try this immediately
Thank you so much for your work !
I don't really use .srt subs a lot beside for some TV shows, and use PGS for movies mainly. I do however experience this issue when using Plex for Kodi addon. It might be because the way it has a different OSD overlay over Kodi, so most my media stutter every second (no dropped frames though in codecinfo) no matter if I use subtitles or not.
This issue has caused me to use PlexKodiConnect instead, which does not experience this issue with the same files on the same device.
This issue has only seemed to happen on my Minix U9 and not any other Kodi running device (Sony Android TV, Windows).
using wrxtasy build finally fixed this issue for me. Thanks a lot.
Indeed, problem is also fixed by my side.
Thank you so much !!
Thx wrxtasy, now everything is ok with subtitles, silky smooth
