Hi,
I've been trying to get the 8.2.0 x64 generic installed on a couple of machines.
First machine wouldn't install properly for an hour and a half then finally worked after another flash the usb image/install cycle.
Thought it must have been some bad flashing of the usb or install to hard disk for the previous 90 minutes.
been trying for a couple of hours to install on a different machine this morning with initially the same usb image then different usb stick and reflashing then multiple install attempts to the machines hard disk.
All have the same problems -
Cannot install addons - E.G try to change the skin by "get more" but instead of a list of downloads nothing happens - just goes back to previous screen.
Same for all addons.
Can't browse shares to my main synology box.
Can't restore a backup - it goes through the motions and reboots but doesn't restore anything.
I CAN see this machine on the network and access it's chares - hence being able to copy over a backup file to it.
I can also browse to other libreelec machines on the network.
It's like the installer isn't working properly.
In the kodi log I see lots of lines like:
09:40:57.620 T:139977665009408 DEBUG: CAddonDatabase: SELECT repo.id FROM repo .. took 0 ms
09:40:57.620 T:139977665009408 DEBUG: CAddonDatabase: no valid repository matching ''
09:40:57.620 T:139977665009408 ERROR: GetDirectory - Error getting addons://all/
09:40:59.660 T:139977631438592 ERROR: GetDirectory - Error getting
09:41:00.824 T:139978265652544 ERROR: GetDirectory - Error getting addons://sources/
09:41:00.824 T:139978265652544 ERROR: CGUIMediaWindow::GetDirectory(addons://sources/) failed
09:43:00.922 T:139978265652544 ERROR: Window Translator: Can't find window videolibrary
09:43:00.967 T:139978265652544 ERROR: Control 1000 in window 13001 has been asked to focus, but it can't
10:35:46.209 T:139860788682048 INFO: ADDON: cpluff: 'Could not read plug-in directory /storage/.kodi/addons: No such file or directory'
10:35:46.242 T:139860788682048 INFO: ADDON: cpluff: 'Could not read plug-in directory /usr/lib/kodi/addons: No such file or directory'
10:35:47.346 T:139859972847360 WARNING: CSkinInfo: failed to load skin settings
Trying to restore:
11:04:23.683 T:139860788682048 DEBUG: ------ Window Deinit (FileBrowser.xml) ------
11:04:23.703 T:139860523419392 ERROR: ## LibreELEC Addon ## oe::copy_file ## SOURCE: /storage/backup/libreelec8.2freshbackup.tar, DEST: /storage/.restore/libreelec8.2freshbackup.tar
11:04:23.704 T:139860523419392 ERROR: None
11:04:23.704 T:139860523419392 DEBUG: DialogProgress::Open called
Anyone got any ideas?
Cheers!
