  • wrxtasy, Tim_Taylor
    Thanks for the explanations.:thumbup:
    I'm just interested in these keys:
    Pause / play, stop, back, rewind, forward, ok, power, and directional arrows.
    On kodi (on windows 10) I installed the Keymap Editor Addon but it does not work.
    A remote control with the keys already mapped I think it does not exist.:?:
    I've seen the advice of the Xiaomi Mi Box Bluetooth, but it has a few buttons.
    EDIT :
    Summary:
    Favorite Box Android:
    s905: minix neo u1, wetek play2
    s905x: Beelink MiniMXIII II, Mini M8S II, MECOOL M8S Pro +
    s912: Minix neo u9-h, MECOOL M8S PRO, Beelink GT1 Ultimate, H96 Pro +
    s905H: WeTek Hub
    s905D: MECOOL KI PRO TV
    Favorite remote controls: Minix A2 lite, Mele f10, Xiaomi Mi Bluetooth
    Edited 3 times, last by marck120 ().
  • One question, the fast ports of the s905x (100 Mbps) boxes can support streaming (local network) of 4k files ? Perhaps the maximum bitrate of a 4k video file is 50/60 Mbps, I do not think I exceed 100 Mbps.
    Depends on the 4k file.
    I use GBit USB-Network adapter
  • Please go ask minix about their plans for Android directly. This is a forum about Linux, not Android.
    Hi, sorry I did not think I was out of the question, the minix u1 has the s905 so how the thread title comes into the discussion. Can I ask you which box to use with libreelec ? Which box advises me ?
  • Depends on the 4k file.
    What adapter are you using? brand
    I saw in gearbest something like that adapters for 5€
    Do you think it will works on box?
    - Box Android Mini M8S II (Amlogic S905X, 2GB RAM, 8GB ROM)
    - Ugreen USB Ethernet Adapter Usb 3.0 2.0 [ASIX AX88179 Chipset]
    - LibreELEC 8.2 (Nougat Kernel) builds aimed at devices based on Amlogic S905/S905X SoC.
  • What adapter are you using? brand
    My adapter -> see signature
    Chipset is important -> ASIX AX88178 Chipset working oob with old kernel and android
    RTL8153 based adapter will work with LE but not with android
    Cheap 5€ adapter -> bad idea
  • I have two usb 3.0-gigabit adapter, one with ASIX 88179 and the other with RTL8153 chip.
    Both work fine with any box under LE and android.
    pel.hu
    But is it necessary to take the gigabit adapter ? 100 mbps are so many, I think a few video files exceed a bitrate of 100 mbps.
    But your box supports USB 3.0?
  • Yes, it is if You want to watch 4k movies
    Tested with files from
    Jellyfish Bitrate Test Files
    Thank you very kind, perfect, I have seen the table you showed me, the situation is very clear. Ok I saw that for 100 Mbps 1080p files are enough, for now I do not have 4k files on the hard disk.
    I've seen you use this adapter:
    ref=cm_cr_arp_d_product_top?ie=UTF8
    Sorry if i bother you, just a question about the micro SDs that I recommend these models ?
  • But your box supports USB 3.0?
    No. It is not necessary. USB 3.0 is backward compatible with USB 2.
    pel.hu
  • No. It is not necessary. USB 3.0 is backward compatible with USB 2.
    But USB 2.0 don't support 1000mb only 100mb
  • But USB 2.0 don't support 1000mb only 100mb
    It is obvious.
    And? Do you have any movie with 1000 mbps?
    I don't really understand that fuss about network bandwith.
    The biggest UHD BD (Lalaland) has about 80 mbps.
    Normal 4k content has much lower bandwith.
    If you want to play all the extreme test videos then connect a gigabit adapter for the S905X box.
    pel.hu
