Problems with Libreelec 8.0.2 and VGA display
  • Hi!
    I have a hp mini 110 148a with libreelec 8.0.2
    I need to work with the laptop as stand alone player but also connect to the TV using VGA cable.
    I have 3 modes
    -LVDS1 Works ok but not is the desired behaviour, I need VGA output.
    -Default. LVDS and VGA works at de same time but VGA output show the entire window resized in a small frame.
    -VGA1. When I change to this mode, the 2 outputs (VGA and laptop) goes to black, I only see the pointer on the VGA. So I do the following
    • I click on left and press enter to accept the new configuration
    • reboot
    • After reboot, I see the window cropped (I not see en entire window, only a portion)
    • If I select "blank other displays" and reboot the system again I see the VGA at full screen
    xrandr give me this values connected to one VGA external monitor:
    Also mote that fn+f4 key that I assume that is used to change the output on windows, not works.
    My questions are.
    • How can I get proper logs to get more detailed information? specially to understand what happens when I select "VGA" and the screen goes to black.
    • How can I configure the fn+f4 button?
    • It's possible configure the "default" configuration and see the laptop and VGA at full screen at the same time?
    Edited once, last by CGarces: add xrandr output (July 25, 2017 at 6:23 PM).
    • Official Post
    try this
    xrandr --output LVDS1 --off && sleep 1 && xrandr --output VGA1 --mode 1280x1024 --rate 60.0
    Note that this will turn off the laptop screen.
