Hello !
Where is the repository for generic addon for a ADS7846 waveshare 10.1 touchscreen with raspbian ? Thank you.
Hello !
raspbian
Here we are talking only about LibreELEC.
I am confused, i have thinking that the addon was for all the system. Sorry.
Well, you can try service.touchscreen-8.1.100.100.zip
But if doesn't work you need to figure out yourself why ![]()
Hi vpeter. I'm having similar issue to Wim.. I'm using a RPI3 with a chalkelec 14" capacitive touch screen. The screen works in raspbian but with libreelec I can't get the touch screen service to start. I have modified ts_env.sh and ts_conf as per your instructions, including the screen name in dev/input/event2 but the service wont start.
I attach evtest and service status.. any ideas would be wonderful as its an awesome screen..
LibreELEC:~ # systemctl stop kodi
LibreELEC:~ # evtest
No device specified, trying to scan all of /dev/input/event*
Available devices:
/dev/input/event0: Logitech Logitech BT Mini-Receiver
/dev/input/event1: Logitech Logitech BT Mini-Receiver
/dev/input/event2: ELAN Touchscreen
Select the device event number [0-2]: 2
Input driver version is 1.0.1
Input device ID: bus 0x3 vendor 0x4f3 product 0x196 version 0x110
Input device name: "ELAN Touchscreen"
Supported events:
Event type 0 (EV_SYN)
Event type 1 (EV_KEY)
Event code 330 (BTN_TOUCH)
Event type 3 (EV_ABS)
Event code 0 (ABS_X)
Value 0
Min 0
Max 3968
Resolution 12
Event code 1 (ABS_Y)
Value 0
Min 0
Max 2240
Resolution 12
Event code 47 (ABS_MT_SLOT)
Value 0
Min 0
Max 9
Event code 48 (ABS_MT_TOUCH_MAJOR)
Value 0
Min 0
Max 255
Resolution 1
Event code 49 (ABS_MT_TOUCH_MINOR)
Value 0
Min 0
Max 255
Resolution 1
Event code 52 (ABS_MT_ORIENTATION)
Value 0
Min 0
Max 1
Event code 53 (ABS_MT_POSITION_X)
Value 0
Min 0
Max 3968
Resolution 12
Event code 54 (ABS_MT_POSITION_Y)
Value 0
Min 0
Max 2240
Resolution 12
Event code 57 (ABS_MT_TRACKING_ID)
Value 0
Min 0
Max 65535
Event code 60 (ABS_MT_TOOL_X)
Value 0
Min 0
Max 3968
Resolution 12
Event code 61 (ABS_MT_TOOL_Y)
Value 0
Min 0
Max 2240
Resolution 12
Properties:
Property type 1 (INPUT_PROP_DIRECT)
Testing ... (interrupt to exit)
Event: time 1500058494.531234, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value 0
Event: time 1500058494.531234, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 39
Event: time 1500058494.531234, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 44
Event: time 1500058494.531234, type 3 (EV_ABS), code 60 (ABS_MT_TOOL_X), value 39
Event: time 1500058494.531234, type 3 (EV_ABS), code 61 (ABS_MT_TOOL_Y), value 44
Event: time 1500058494.531234, type 3 (EV_ABS), code 48 (ABS_MT_TOUCH_MAJOR), value 1
Event: time 1500058494.531234, type 3 (EV_ABS), code 49 (ABS_MT_TOUCH_MINOR), value 1
Event: time 1500058494.531234, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1500058494.531234, type 3 (EV_ABS), code 0 (ABS_X), value 39
Event: time 1500058494.531234, type 3 (EV_ABS), code 1 (ABS_Y), value 44
Event: time 1500058494.531234, -------------- SYN_REPORT ------------
Event: time 1500058494.539212, type 3 (EV_ABS), code 48 (ABS_MT_TOUCH_MAJOR), value 2
Event: time 1500058494.539212, type 3 (EV_ABS), code 49 (ABS_MT_TOUCH_MINOR), value 2
Event: time 1500058494.539212, -------------- SYN_REPORT ------------
Event: time 1500058494.555200, type 3 (EV_ABS), code 48 (ABS_MT_TOUCH_MAJOR), value 3
Event: time 1500058494.555200, type 3 (EV_ABS), code 49 (ABS_MT_TOUCH_MINOR), value 3
Event: time 1500058494.555200, -------------- SYN_REPORT ------------
Event: time 1500058494.594226, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value -1
Event: time 1500058494.594226, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Event: time 1500058494.594226, -------------- SYN_REPORT ------------
Event: time 1500058495.750084, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value 1
Event: time 1500058495.750084, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 3968
Event: time 1500058495.750084, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 39
Event: time 1500058495.750084, type 3 (EV_ABS), code 60 (ABS_MT_TOOL_X), value 3968
Event: time 1500058495.750084, type 3 (EV_ABS), code 61 (ABS_MT_TOOL_Y), value 39
Event: time 1500058495.750084, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1500058495.750084, type 3 (EV_ABS), code 0 (ABS_X), value 3968
Event: time 1500058495.750084, type 3 (EV_ABS), code 1 (ABS_Y), value 39
Event: time 1500058495.750084, -------------- SYN_REPORT ------------
Event: time 1500058495.758077, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 3964
Event: time 1500058495.758077, type 3 (EV_ABS), code 60 (ABS_MT_TOOL_X), value 3964
Event: time 1500058495.758077, type 3 (EV_ABS), code 0 (ABS_X), value 3964
Event: time 1500058495.758077, -------------- SYN_REPORT ------------
Event: time 1500058495.773079, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 3962
Event: time 1500058495.773079, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 38
Event: time 1500058495.773079, type 3 (EV_ABS), code 60 (ABS_MT_TOOL_X), value 3962
Event: time 1500058495.773079, type 3 (EV_ABS), code 61 (ABS_MT_TOOL_Y), value 38
Event: time 1500058495.773079, type 3 (EV_ABS), code 0 (ABS_X), value 3962
Event: time 1500058495.773079, type 3 (EV_ABS), code 1 (ABS_Y), value 38
Event: time 1500058495.773079, -------------- SYN_REPORT ------------
Event: time 1500058495.805101, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 3964
Event: time 1500058495.805101, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 35
Event: time 1500058495.805101, type 3 (EV_ABS), code 60 (ABS_MT_TOOL_X), value 3964
Event: time 1500058495.805101, type 3 (EV_ABS), code 61 (ABS_MT_TOOL_Y), value 35
Event: time 1500058495.805101, type 3 (EV_ABS), code 0 (ABS_X), value 3964
Event: time 1500058495.805101, type 3 (EV_ABS), code 1 (ABS_Y), value 35
Event: time 1500058495.805101, -------------- SYN_REPORT ------------
Event: time 1500058495.812104, type 3 (EV_ABS), code 49 (ABS_MT_TOUCH_MINOR), value 2
Event: time 1500058495.812104, -------------- SYN_REPORT ------------
Event: time 1500058495.820106, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value -1
Event: time 1500058495.820106, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Event: time 1500058495.820106, -------------- SYN_REPORT ------------
Event: time 1500058496.837855, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value 2
Event: time 1500058496.837855, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 3954
Event: time 1500058496.837855, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 2240
Event: time 1500058496.837855, type 3 (EV_ABS), code 60 (ABS_MT_TOOL_X), value 3954
Event: time 1500058496.837855, type 3 (EV_ABS), code 61 (ABS_MT_TOOL_Y), value 2240
Event: time 1500058496.837855, type 3 (EV_ABS), code 49 (ABS_MT_TOUCH_MINOR), value 3
Event: time 1500058496.837855, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1500058496.837855, type 3 (EV_ABS), code 0 (ABS_X), value 3954
Event: time 1500058496.837855, type 3 (EV_ABS), code 1 (ABS_Y), value 2240
Event: time 1500058496.837855, -------------- SYN_REPORT ------------
Event: time 1500058496.915891, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value -1
Event: time 1500058496.915891, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Event: time 1500058496.915891, -------------- SYN_REPORT ------------
Event: time 1500058497.909621, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value 3
Event: time 1500058497.909621, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 21
Event: time 1500058497.909621, type 3 (EV_ABS), code 60 (ABS_MT_TOOL_X), value 21
Event: time 1500058497.909621, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1500058497.909621, type 3 (EV_ABS), code 0 (ABS_X), value 21
Event: time 1500058497.909621, -------------- SYN_REPORT ------------
Event: time 1500058497.917623, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 22
Event: time 1500058497.917623, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 2238
Event: time 1500058497.917623, type 3 (EV_ABS), code 60 (ABS_MT_TOOL_X), value 22
Event: time 1500058497.917623, type 3 (EV_ABS), code 61 (ABS_MT_TOOL_Y), value 2238
Event: time 1500058497.917623, type 3 (EV_ABS), code 48 (ABS_MT_TOUCH_MAJOR), value 4
Event: time 1500058497.917623, type 3 (EV_ABS), code 0 (ABS_X), value 22
Event: time 1500058497.917623, type 3 (EV_ABS), code 1 (ABS_Y), value 2238
Event: time 1500058497.917623, -------------- SYN_REPORT ------------
Event: time 1500058497.933617, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 2235
Event: time 1500058497.933617, type 3 (EV_ABS), code 61 (ABS_MT_TOOL_Y), value 2235
Event: time 1500058497.933617, type 3 (EV_ABS), code 1 (ABS_Y), value 2235
Event: time 1500058497.933617, -------------- SYN_REPORT ------------
Event: time 1500058497.949632, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 2233
Event: time 1500058497.949632, type 3 (EV_ABS), code 61 (ABS_MT_TOOL_Y), value 2233
Event: time 1500058497.949632, type 3 (EV_ABS), code 1 (ABS_Y), value 2233
Event: time 1500058497.949632, -------------- SYN_REPORT ------------
Event: time 1500058497.980644, type 3 (EV_ABS), code 57 (ABS_MT_TRACKING_ID), value -1
Event: time 1500058497.980644, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Event: time 1500058497.980644, -------------- SYN_REPORT ------------
? service.touchscreen.service - Touchscreen support daemon
Loaded: loaded (/storage/.kodi/addons/service.touchscreen/system.d/service.touchscreen.service; enabled; vendor preset: disabled)
Active: active (exited) since Fri 2017-05-19 14:01:29 UTC; 1 months 25 days ago
Process: 569 ExecStart=/bin/sh -c exec /bin/sh /storage/.kodi/addons/service.touchscreen/bin/ts_uinput_touch.sh service (code=exited, status=1/FAILURE)
Process: 541 ExecStartPre=/bin/sh -c exec /bin/sh /storage/.kodi/addons/service.touchscreen/bin/ts_calibrate.sh service (code=exited, status=0/SUCCESS)
Main PID: 569 (code=exited, status=1/FAILURE)
CGroup: /system.slice/service.touchscreen.service
May 19 14:01:29 LibreELEC sh[569]: TSLIB_PLUGINDIR: '(null)'
May 19 14:01:29 LibreELEC sh[569]: TSLIB_CONSOLEDEVICE: '(null)'
May 19 14:01:29 LibreELEC sh[569]: TSLIB_FBDEVICE: '(null)'
May 19 14:01:29 LibreELEC sh[569]: TSLIB_CALIBFILE: '(null)'
May 19 14:01:29 LibreELEC sh[569]: TSLIB_CONFFILE: '(null)'
May 19 14:01:29 LibreELEC sh[569]: TSLIB_RES_X: '(null)'
May 19 14:01:29 LibreELEC sh[569]: TSLIB_RES_Y: '(null)'
May 19 14:01:29 LibreELEC sh[569]: TSLIB_TOUCH_HOME_TIME: '(null)'
May 19 14:01:29 LibreELEC sh[569]: resolution: 0x0
May 19 14:01:29 LibreELEC systemd[1]: Started Touchscreen support daemon.
Display More
This is the problem i figure:
Unit ts_uinput_touch.service could not be found.
i feel the file is not where it should be!
its IS in addons/service.touchscreen/bin and it looks like this
. /etc/profile
oe_setup_addon service.touchscreen
if [ -d /usr/share/kodi/addons/service.touchscreen ]; then
# addon included in image
ADDON_DIR="/usr/share/kodi/addons/service.touchscreen"
fi
. $ADDON_DIR/bin/ts_env.sh
params=$*
if [ "$1" = "service" ]; then
# skip service parameter and daemonize
params="-d"
else
# started from command line
systemctl stop ts_uinput_touch >/dev/null 2>&1
killall ts_uinput_touch >/dev/null 2>&1
fi
echo " touchscreen device: '$TSLIB_TSDEVICE'"
if [ -n "$TSLIB_RES_X" -a -n "$TSLIB_RES_Y" ]; then
echo "touchscreen resolution: '${TSLIB_RES_X}x${TSLIB_RES_Y}'"
params="-x $TSLIB_RES_X -y $TSLIB_RES_Y $params"
fi
echo "params: .$params."
if [ ! -x $ADDON_HOME/ts_uinput_touch ]; then
ts_uinput_touch $params
else
echo "Using $ADDON_HOME/ts_uinput_touch"
$ADDON_HOME/ts_uinput_touch $params
fi
Display More
● service.touchscreen.service - Touchscreen support daemon
Active: active (exited) since Fri 2017-05-19 14:01:31 UTC; 1 months 26 days a
go
Process: 522 ExecStart=/bin/sh -c exec /bin/sh /storage/.kodi/addons/service.t
Process: 492 ExecStartPre=/bin/sh -c exec /bin/sh /storage/.kodi/addons/servic
Main PID: 522 (code=exited, status=1/FAILURE)
May 19 14:01:31 LibreELEC sh[522]: TSLIB_PLUGINDIR: '(null)'
May 19 14:01:31 LibreELEC sh[522]: TSLIB_CONSOLEDEVICE: '(null)'
May 19 14:01:31 LibreELEC sh[522]: TSLIB_FBDEVICE: '(null)'
May 19 14:01:31 LibreELEC sh[522]: TSLIB_CALIBFILE: '(null)'
May 19 14:01:31 LibreELEC sh[522]: TSLIB_CONFFILE: '(null)'
May 19 14:01:31 LibreELEC sh[522]: TSLIB_RES_X: '(null)'
May 19 14:01:31 LibreELEC sh[522]: TSLIB_RES_Y: '(null)'
May 19 14:01:31 LibreELEC sh[522]: TSLIB_TOUCH_HOME_TIME: '(null)'
May 19 14:01:31 LibreELEC sh[522]: resolution: 0x0
May 19 14:01:31 LibreELEC systemd[1]: Started Touchscreen support daemon.
Display More
Seems you forgot to copy file ts_env.sh-sample to ts_env.sh and adjust it (changing TOUCHSCREEN_NAME="ELAN Touchscreen"). Also copying file file ts.conf-generic to ts.conf.
no i've definitely done that
TOUCHSCREEN_NAME="Elan TouchScreen"
TSLIB_TSDEVICE=$(echo 999 | evtest 2>&1 >/dev/null | awk -F':' -v TS_NAME="$TOUCHSCREEN_NAME" '$0 ~ TS_NAME {print $1; exit}')
export TSLIB_TSDEVICE
export TSLIB_PLUGINDIR=$ADDON_DIR/lib
export TSLIB_CONSOLEDEVICE=none
export TSLIB_FBDEVICE=/dev/fb0
export TSLIB_CALIBFILE=/storage/.kodi/userdata/addon_data/service.touchscreen/pointercal
export TSLIB_CONFFILE=/storage/.kodi/userdata/addon_data/service.touchscreen/ts.conf
there are two ts_env.sh
one is in /bin and the other in /config
they are not the same though
You need to copy/edit files only in /storage/.kodi/userdata/addon_data/service.touchscreen. There should be config folder.
In one of your previous posts I saw
which indicates not everything is configured properly.
WOOOOHOOOO!!!!
There appears to be 2 similar directories here..
/storage/.kodi/userdata/addon_data/service.touchscreen - here i have copied ts.conf-generic to ts.conf and ts_env.sh-sample to ts_env.sh
/storage/.kodi/addons/service.touchscreen - here are the generic files.. there is no /config subdir.. So i just copied them there too and we are sorted!
Thanks so much.. i have a 14 inch glass 3mm thick touchscreen running libreelec KODI krytpon. Its the bollocks.
You rock.. thanks
