- Official Post
both, just use LE defaults and copy the icons from PICONS - Home
srp-full.400x240-400x240.light.on.transparent_$DATE.hardlink.tar.xz
snp-full.400x240-400x240.light.on.transparent_$DATE.hardlink.tar.xz
copy to /storage/picons , reboot
Hmm, shouldn't they be copied to and configured with TVHeadend?
Perfect! Works! Thanks again!
Yesterday during a huge thunderstorm affecting my sat signal I realized that the "Signal Strength" and "SNR" stats will only get updated once when the channel is switched to. While watching the channel the stats won't get updated any more. You need to switch channels forth and back to update the stats.
As this used to work in combination with my old Wetek Play, I suppose this is related to satip-axe. Is there any setting that I need to change to get stats updated regularly?
not that I am aware of, but keep in mind SNR levels are mostly bogus - nothing you can relay on
