Just tested. Working perfectly. Thank you !!
Wake from suspend (CEC)
Marino -
April 2, 2017 at 10:41 PM -
Thank you vpeter, could you kindly build an image for the Odroid C2? Many thanks!
Hope it is this: LibreELEC-Odroid_C2.aarch64-8.2.1-libcec-3953f8d.img.gz
I'll try as soon as possible, thanks!
8.2.2 for RPi2(3)?
Thanks!
Thank you very much!
One question: Can you give me your build environment? (gcc version, libc6 version and so on?). Until now I was not able to compile LibrELEC by my own successfully
Up to date Ubuntu 16.04.3 LTS - nothing special. It should just work ootb.
I tried to compile it in a debian chroot. I will double check it. Thanks!
If you are familiar with docker try using it.
8.2.2 for RPi2(3)?
Thanks!
Don't think there are any changes effecting the rpi
Hi vpeter, when you get a chance could you make a build for 8.2.2 based on below
LibreELEC-RPi2.arm-8.2.1-libcec-1a8dc6c-commit-d9407d3.img.gz
thanks in advance
Any way to get 8.2.2 x86_64 version? and does this fix the cec problem? Il check out 8.2.1 version.
LibreELEC-Generic.x86_64-8.2.2-libcec-3953f8d.img.gz
I did build previous version so it fix for at least someone
wow that was fast :O. Going to make reinstall now
Thank you
No need for reinstall: just update.
How do I configure it, because system/system settings/inputs/peripherals is grayed out and not active in my intel nuc. and if I turn off or susped my htpc the lg receiver still remains on
