Compile Sapphire remote driver
  • Hello,
    Anyone have this driver working with LibreElec?
    I try lots of times but I can not get it working. It looks like the device is using topseed driver instead of sapphire. It never change the last_key:
    # cat /proc/sapphire
    event_count 2
    last_key 0x00000000
    elapsed_secs 313
    Need I disable any IR module? The sapphire module is loaded in every reboot:
    # lsmod | grep sapphire
    sapphire                8260  0
    I waill really appreciate your help, I used this remote with MythTV and it is very flexible for long-press buttons.
    Kind regards.
  • Thanks CvH,
    Yes, I am using LE oficial addon:
    Before o install the latest version I want to be sure that it works for others.
    Kind regards.
