Hi All,
Had a look through the forums, Google, LE8 release notes and the Kodi Audio Quickstart guide but can't seems to get any sound out via S/PDIF. For the record, it works OK via HDMI.
Dmesg seems to indicate that it is detected OK, and I've tried both the 'default' option and selecting S/PDIF manually. Have also enabled passthrough to see if it makes a difference but nothing. I had the same issue when I tried one of the beta builds and just downgraded back to 7.0.2 and it worked again, so I'm ruling out broken hardware.
CuBox:~ # dmesg | grep spdif
[ 2.218517] imx-spdif sound-spdif: snd-soc-dummy-dai <-> 2004000.spdif mapping ok
[ 2.246172] ALSA device list:
[ 2.246187] #0: imx-spdif
[ 2.246193] #1: imx-hdmi-soc
Any ideas, and any other log files I can sift through to find an answer?
Much appreciated.
