Sx05RE v1.8.6 Emulationstation+Lakka+Kodi
  • It's not that, so do I.
    BUT!!!
    I finally figured it out ;). The flag needed for Emulatiostation to get rid of the errors is "-ldl" (not sure if "-lm" is necessary).
    The kodi part is the latest stock kszaq 8.0.0c build, and i just need to check and iron things regarding games now.
    I left libretro-ppsspp disabled for now.
    NICE!! i am compiling it right now :)
    also the packages that have "none" or "" you cn just use the PKG_SITE value and they will compile :)
    does sound work for you? if not, its because asound.conf is missing :)
    edit: for me, it does not compile with just -ldl. it needs -ldl and -lm
    Edited once, last by niabi (February 24, 2017 at 6:59 AM).
  • NICE!! i am compiling it right now :)
    I left both switches also...
    I need to do some (a lot) of config changes to ES and Retroarch.
    ES quits on start, complains about missing stuff (remote, roms, etc). But at least it does not crash.
    I'll zip it all for you to take a look and perhaps help with the config changes.
    Nice work :) :) .
    So in all: Clone kszaq's repo (8.0.0c), then copy the entire xmedia folder from your repo in to Libreelec/packages (first), and then merge everything included in my zip.
    Kszaq + Games.zip
    A lot of game packages in the zip, simply have the source url changed, the ones from your repo didn't work.
    Haven't messed with the PKG_SITE values, need to figure out what needs changing in ES config.
    Edited once, last by Asxetos (February 24, 2017 at 8:05 AM).
  • hahaha I made a repository with all the changes.
    GitHub - shantigilbert/LibreELEC.tv: 'Just enough OS' for Kodi. Sx05 Retro Edition, an emulation build based on LibreELEC for S905, S805 Devices.
    feel free to push any changes you make
    Tomorrow I will check what needs to be changed so that Kodi doesn't fight ES :)
    and make a patch to start ES directly from Kodi, it seems more people want it like this (start Kodi then the games).
    btw: I don't think we need libretro PPSSPP, its outdated, I think the standalone is better.
    Edited once, last by niabi (February 24, 2017 at 8:32 AM).
  • I have no idea how to push changes on github :sick: :D . Never messed with it (that's your department).
    Is it my imagination, or are the changes missing from the new repo?
    Any way, later tonight again...
    Edited once, last by Asxetos (February 24, 2017 at 8:50 AM).
    no, they are there, you just need to select the branch (Sx05RE) and inside the sx05re folder, I am trying to have it all separated.
    but there is another problem on my side.
    LibreELEC:~ # emulationstation
    lvl0: Error initializing SDL!
    SDL not built with video support
    lvl0: Renderer failed to initialize!
    lvl0: Window failed to initialize!
    edit: nevermind, fixed :)
    Edited once, last by niabi (February 24, 2017 at 9:04 AM).
  • no, they are there, you just need to select the branch (Sx05RE) and inside the sx05re folder, I am trying to have it all separated.
    Ok. ES config corrected (to a point) but i get the same as you.
    It must be an sdl2 config thing, but i am not that of an expert :( .
    How did you fix it?
    Edited once, last by Asxetos (February 24, 2017 at 6:33 PM).
  • Ok. ES config corrected (to a point) but i get the same as you.
    How did you fix it?
    it seems the fieldofcows version of ES does not like the way we compile it (with -ldl -lm) so it complains, if you go back to "https://github.com/RetroPie/EmulationStation" it works, but I also rolled back to SDL2 2.0.4 from my las build, because it has some patches relate to mali (I haven't tested it with 2.0.5)
  • I added asound.conf to the s905 project, added emulationstation to the exit menu in Kodi, and fixed some ES settings.
    so right now the project is now 99% ported to Kszaqs LE 8, as many people requested, it starts kodi first, then you can choose ES from the exit menu.
    here is the source, no binaries yet.
    Edited once, last by niabi (February 25, 2017 at 7:32 AM).
    It's not working on me...
    Edited once, last by Asxetos (February 25, 2017 at 3:58 PM).
  • What isn't?
    Sent from my Lenovo K50-t5 using Tapatalk
    Starting ES from Kodi freezes the Gui. Perhaps checking the exit patches would fix it (in combination that emustation-config in /usr/bin is not made executable).
    I did it manually through ssh, and ES can finally be started (needs config checking). Don't have much time tonight for more troubleshooting...
  • Starting ES from Kodi freezes the Gui. Perhaps checking the exit patches would fix it (in combination that emustation-config in /usr/bin is not made executable).
    are you using make image PROJECT=S905 ARCH=arm? and switching to your correct dtb after writing to SD?
    it seems weird that it works for me (emulationstation-config ran with no problem), and I can exit to ES without any manual changes, not sure why the differences.
  • are you using make image PROJECT=S905 ARCH=arm? and switching to your correct dtb after writing to SD?
    Of course i do, and i am not sure either. Is your build a fresh from the new repo or is it a stitch and patch build?
    Just needs looking into...
  • Of course i do, and i am not sure either. Is your build a fresh from the new repo or is it a stitch and patch build?
    its "fresh" fork with my changes applied, but I tried to keep most changes isolated from the main build.
    are you building from my source directly?
  • its "fresh" fork with my changes applied, but I tried to keep most changes isolated from the main build.
    Ok, i figured it.
    Yesterday i deleted everything and started from scratch. FYI everything compiles without a hitch now.
    But for my situation, i still need for KODI to load first for a very good reason. As is (ES loading first) i get NO GUI, and no way to change anything. SSH should be loaded by the autorun script, but it is not.
    After i did that ALL is working good (Exit to games works fine and ES loads ok).
    PS, i think kodi should remain first to load. I am certainly not the only one with this kind of peculiarities.
    But all and all i think you can call it a success!!!
    Edited once, last by Asxetos (February 26, 2017 at 2:18 PM).
  • Ok, i figured it.
    Awesome news!
    I made a few fixes and changes since last time I posted the link to the source.
    Ssh loads by default now.
    I changed the way kodi starts, but it's very easy to fix that before you compile it, just change the autostart.sh located in the Retroarch package.
    BTW: what do you mean you get no GUI at first? does ES not start at all?
    Anyways the "first" binary release using LE 8 from Kszaq will have Kodi launch first.
    I just pushed 2 updates to the source on the sx05re branch
    Made changes to autostart.sh so that Kodi will launch by default.
    used chmod +x on emulationstation-config to force it to be executable.
    can you please pull the changes to your computer and try and compile it again? :)
    Thanks!
    Edited once, last by niabi (February 26, 2017 at 6:31 PM).
  • I pulled them, but i can't do a new compile till tomorrow. Anyway it's just minor details. Important stuff is working as they should now.
    For the gui problem i have, i think it is part my TV and part ES to blame. It's an older Sony model and i think ES does not like the auto-detected resolution (720p). If i boot to kodi first and change the resolution to 1080, then ES works ok too. But as i said i probably am not the only one...
    PS, I thought perhaps the roms folder should be added to smb.conf to make it accessible (instead of "emulators" folder which is useless).
    Edited once, last by Asxetos (February 26, 2017 at 9:02 PM).
    Yes I noticed the rom folder missing from samba, I already added it on my local build, going to push the changes tonight.
