@SumavisionQ5 ES restart bug fixed and page up/down re-implemented I will upload an update tonight.
Edit: 2.0.1 is uploaded
EmulationStation addons still doesn't works for me on 2.0.1. When I open it, it just stuck on a blinking screen with Sx05re logo
I made another mistake that I already fixed, I am uploading it as we speak
Edit: Uploaded
Now it works very well, thanks
How do you guys play scummvm with the sx095re?
<figured it out> now anyone know how to launch it from emulation station?
Can you share how you did it? We can probably help more with ES if you show what you did to load it.
Oh I just followed this.
1. In retroarch. Load core > ScummVm
2. Dont select Quick menu. Select Start core.
3. There you can add your games.
Other stuff like new themes are found in scummvm website.
Display MoreOh I just followed this.
Have you tried following these suggestions?
if that works it should be trivial to add to ES
It works with a few tweaks on the tutorial. It wasn’t clear so I had to trial and error. Thanks!
If you don't mind, can you share it so others with the same problem can also benefit?
Ok.
In order for this to work you have to add the games manually at retroarch.
For Emulation Station launchers for each game here are the steps.
1. Make sure you create a file inside the folder with the same name of the folder, example is "the 7th guest" so you have to create "the 7th guest.svm" (scummvm as an extension also works but you have to edit the ef_systems.cfg file so stick with the svm file).
2. Inside the file should be the the game short name corresponding the game. Found in this link ScummVM compatibility list. In our case we will input "t7g" inside the file (that is it).
3. Reboot for emulation station and it will see the file.
Hope it helps.
Where can I download the version Sx05RE v2.0.1? , and if you can play the psx games on the Emulationstation.
Thanks in advance
Thanks in advance
Hi, i have your newest release the generic version for S912. Everything works find so far, BUT in Kodi i cannot connect my smb shares, all shares in my sources.xml says "no connection to network server" and in "add network locations" SMB is gone, everything (nfs, http, https, ) in connections is here only SMB is missing. It does not appear in the selection menu.
From all my other Kodi installations (S905, Apple TV (mrmc) and in my Android TV) smb is there and working fine. So it is not a failure on my NAS-Linux-Server.
Did I miss something?!?! Thanks for help and answers.
When you say latest, what version are you referring to exactly?
I need to check this as I haven't notice this.
Just to make sure, you replaced the dtb with the correct one for your device?
I used the V2.3 generic for S912 on Beelink GT Ulti. And with a fresh installation of only CE9 and than your great Emustation as script install, smb works. And yeah i choose the same dtb as in my ONLY CE9 install. Strange :o
so fresh install of Sx05RE 2.3 has no SMB
Fresh install of CE9 with the addon, has SMB
right?
Thanks for the report, I will check this ASAP
right?
Yes
