Turn off LED lights Rasp Pi 3
  • Is there a script that can turn off the 2 LED lights on the front of the Rasp Pi 3? I find them very bright and distracting as the Pi sits under my TV. I'm running LibreELEC (Krypton) v7.95.2 BETA
    Thank you.
    Edited once, last by diameter ().
  • According to the RaspberryPi forums:
    echo 0 >/sys/class/leds/led0/brightness #Turn on
    echo 0 >/sys/class/leds/led1/brightness #Turn off
    led0 = green one
    led1 = red one
    Put the echo lines in .config/autostart.sh and "It should work!" (tm)
    Other than that, there is nothing that a roll of duct tape cannot fix.
    Edited once, last by Klojum ().
  • Regarding the power LED on the Pi 3, it cannot be switched off... See here :
    Missign control for RED "Power LED" · Issue #1332 · raspberrypi/linux · GitHub
