Problem with populatefs
  • When building image from source PROJECT=WeTek_Play ARCH=arm make image it fails at the end with
    image: creating part2...
    image: creating filesystem on part1...
    image: creating bootloader configuration...
    image: installing u-boot bootloader...
    image: copying files to part1...
    image: copying dtb to part1...
    image: extracting part2 from image...
    image: creating filesystem on part2...
    image: populating filesystem on part2...
    image: error happen...
    Error: [Filesystem error] /tmp/tmp.JEExJmHhPb/part2.ext4 cannot be opened.
    There is some bug when building populatefs (i get a 152k binary) built it on ubuntu I get only 42k binary - replaced the one in toolchain with one built on ubuntu host (outside of LE build environment) and build now completes successfully..
  • Error: [Filesystem error] /tmp/tmp.JEExJmHhPb/part2.ext4 cannot be opened.
    Such error was reported but no one knows what the problem was/is.
    Which ubuntu version are you using and I will look how it is build there.
  • I'm on ubuntu 16.10 64-bit.. I may be wrong but if i recall correctly this used to work fine before, however i now re-built everything..
    populatefs builds within toolchain and if i executed it works but fails on command in build script.. these might help it seems like they are different versions and different sizes..
    mark@ubuntu:~/src/LibreELEC.tv$ ls -l ./build.LibreELEC-WeTek_Play.arm-8.0-devel/toolchain/sbin/populatefs
    -rwxr-xr-x 1 mark mark 154264 Dec 30 06:11 ./build.LibreELEC-WeTek_Play.arm-8.0-devel/toolchain/sbin/populatefs
    mark@ubuntu:~/src/LibreELEC.tv$ ./build.LibreELEC-WeTek_Play.arm-8.0-devel/toolchain/sbin/populatefs -V
    populatefs 0.9
    mark@ubuntu:~/src/LibreELEC.tv$ ls -l /usr/bin/populatefs
    -rwxr-xr-x 1 root root 42992 Dec 31 15:28 /usr/bin/populatefs
    mark@ubuntu:~/src/LibreELEC.tv$ /usr/bin/populatefs -V
    populatefs 1.0
    Using EXT2FS Library version 1.43.3
