hadesdevls since I didn't see it in the change logs, any chance we can get the quick change menu for the DV conversions?
I think in Croqs build it is available with a double O tap.
And a big thank you for the 1.0 release, I will try it out tomorrow.
There is a "Change output for this video" button in the player process window (O key), but I can't seem to activate it using the keyboard or the Yatse app. I can only seem to reach it using a mouse.
But there is also a change video output button in the default Estuary skin that is delivered with this build which does work.
hadesdevls Happy to report that the video stuttering I experienced with the Avatar 2 ISO is no longer present in 1.0.
Khazar MrMagic Thanks both. The player information page (O) has "Change output for this video" for that, but MrMagic is right that it can only be reached with a mouse: with a keyboard, a remote or Yatse the focus never gets to it. That is a fault in Hades and I will fix it in the next version, and look at a quicker way to switch the Dolby Vision conversion while a video plays at the same time. Until then, the change of video output in the player controls of Estuary works, as MrMagic found.
MrMagic Great to hear the stutter with the Avatar 2 ISO is gone, thanks for telling me.
Looks like a very solid release, congrats! Will do a fresh install and try out.
ht2tweak Thanks! A fresh install is a good way to see the new defaults; if anything looks off, the diagnostic report (Settings > LibreELEC > System > Submit Log) makes it easy to see why.
Hi hadesdevls I see you copied my DVD-related PR in your build, I don’t care that you use the code or the idea obviously it’s what open source is for but my PR was still WIP, untested. I do think most if not all of it is fine but maybe wait a bit before porting stuff to your build, no need to rush!
CorentinB Hi, thanks for reaching out about it, and for the work you shared. The film detection for DVDs in Hades builds on your pull request 101 to the build of CroqueMr: the idea and the approach with fieldmatch and decimate come from there, and I adapted them to how Hades decodes and presents video, with its own checks and tests. You are credited for it in the README and the changelog, as you should be. The measured display latency in 1.0 also grew from something you pointed out in another pull request; that credit is only in the commit for now, and I will add it to the README and the changelog as well.
And fair point about it still being in progress, I appreciate the heads-up. In Hades it is marked as not tried on hardware yet, and I will gladly follow your pull requests and bring in your improvements as they come. It is great to see more people working on DVD and timing on PC, so thanks again, and if you would like the credit worded any differently, just let me know.
