IPT, as licensed players send it. Profiles 7 and 8 reach the TV in IPT-PQ-c2, converted in floating point and packed with the matrices that profile 5 films carry. The TV no longer converts the YCbCr itself, so the colour between the two pixels of each chroma pair no longer depends on how it interpolates. Profile 5 is unchanged, byte for byte.
Can you explain this a bit more? Profile 7 and 8 content is in YCbCr in the actual file, so decodes to YCbCr in 4:2:0. Which then needs to be upsampled to 4:2:2.
How can you then output this in IPT without needing to introduce another upsampling to 4:4:4 in order to apply the conversion to get to IPT color-space from the YCbCr pixels? And then need to downsample again to get 4:2:2 for the tunnel?
