VacuumTube with Multichannel Audio and Auto HDR Switching
  • frodo19  ashlar I managed to add this, having option for default is straightforward once we learn how it's done, video below. I went further and added our own scrollbar, and once in the menu, pressing up on first item puts focus on last item (previously you couldn't quickly go to the bottom of the list from the top and with up to 156 new languages, scroll bar seemed fit)
    External Content youtu.be
    I'll share my work once you have free time.
    what other things does smartube have that people are interested in?
    Please, if you're interested in me implementing these extra functionality, attach your code on a file sharing service and not directly on Google Drive where it asked me to log in. I'm not gonna dox myself for this, sorry.
  • Please, if you're interested in me implementing these extra functionality, attach your code on a file sharing service and not directly on Google Drive where it asked me to log in. I'm not gonna dox myself for this, sorry.
    yeah will do. I normally add to my gist in github but no github :( lol
    I'll probably have to create a new one, I'll post later with all my mods in one source code zip file. AI should be able to copy what you want, since it's very similar
  • fyi this addon doesn't work on the YBLOD builds with the following error:
    Nov 19 19:37:04 LibreELEC kodi-run-external[22933]: /storage/.kodi/addons/tools.hyprland/bin/Hyprland: error while loading shared libraries: libXrender.so.1: cannot open shared object file: No such file or directory
    Not sure why that library is needed as you are building Hyprland with NO_XWAYAND already.
    I don't know if recent vanilla LE builds are also missing libXrender.
    Also the Hyprland add-on isn't visible in my installed add-ons list even though it's installed, so there is no way to remove it or check it's version etc.
    Worked that bit out the addon.xml needs a script defined, even if its just a stub:
      <extension point="xbmc.python.script" library="default.py">
        <provides></provides>
      </extension>
    and a very simple default.py like:
    import xbmcgui
    dialog = xbmcgui.Dialog()
    dialog.ok('', 'This addon has no options')
    Edited 3 times, last by nissel (November 19, 2026 at 8:35 PM).
  • Also the Hyprland add-on isn't visible in my installed add-ons list even though it's installed, so there is no way to remove it or check it's version etc.
    Doesn't it show in the system addons? I seem to remember checking that it was there. But I might be wrong, I'll look at this.
    Maybe open an issue on GitHub? So I don't forget about it...
    EDIT: I checked and you're right. It doesn't show in dependecies, even if it's listed as a dependency for the addon itself (all dependencies have minimum version at 0.0.0.0 so that's wrong as well).
  • uploaded my source code
    VC/VacuumTube_v0.7.18_Kodi_Sounds_Video_Silent_OSD_Grey_Row_Fix_SOURCE.zip at main · user45454654343/VC
    Contribute to user45454654343/VC development by creating an account on GitHub.
    github.com
    added kodi navigation sounds when not playing a video
    configurable in settings, on by default, you can change as you wish
    Code Nov 19 19:37:04 LibreELEC kodi-run-external[22933]: /storage/.kodi/addons/tools.hyprland/bin/Hyprland: error while loading shared libraries: libXrender.so.1: cannot open shared object file: No such file or directory
    I ashamedly provide a response by Gemini:
    NO_XWAYLAND only disables XWayland client support (xcb* window-management integration and the Xwayland server binary)—it does not prevent Hyprland's dependencies from linking against X11 rendering libraries when compiled against a standard LibreELEC Generic sysroot.
    Why libXrender.so.1 is required
    • Transitive library dependencies (cairo & libXcursor:( Hyprland links directly against cairo / pangocairo (for rendering text, borders, and overlay notifications) and libXcursor / hyprcursor (for cursor theme loading). When built inside a standard LibreELEC Generic.x86_64 sysroot—which builds with DISPLAYSERVER="x11"—cairo is compiled with --enable-xlib-xrender, and libXcursor links directly against libXrender.so.1 and libXfixes.so.3.
    • Why your NUC 11 worked while the reporter's build failed: Standard LibreELEC Generic.x86_64 images (including libreelec-x86-DV) ship Xorg in the read-only OS squashfs (/usr/lib/libXrender.so.1), so tools.hyprland did not need to bundle it in its add-on lib/ directory. The reporter is running a GBM / Wayland-only LibreELEC build (such as Generic-wayland or a custom build with X11 disabled) where Xorg libraries are absent from /usr/lib, causing the dynamic linker to fail at startup.
    If it can be trusted, I am not going to support builds that don't provide standard LibreELEC libraries. Sorry.
  • Don't trust Gemini, it will convincingly tell you the moon is made of cheese.
    Neither are Generic images built with DISPLAYSERVER=x11 (that was a very very long time ago) nor are there libX... libraries in the current Generic images.
    Yup... that's why I closed with "If it can be trusted"... Thanks for confirming it cannot... LOL. I'll see what I can do about that problem, then. Does this mean that library is included in CroqueMr builds but it's not included by the main branch of LibreELEC official.
  • I think Gemini is partially right, but looking at all the build config it looks like only generic-legacy builds include DISPLAYSERVER="x11" which CB1 is not. Generic builds set DISPLAYSERVER="no".
    So it's not quite a clean cut as it says but clearly YBLOD is missing the lib for some reason.
    Have you tried a mainline LE nightly?
  • Sorry, no idea what's in the CroqueMr builds - I never used one and I'm not following it's development.
    Well, ok. But is the library not included in the main branch of LibreELEC official builds? EDIT: I should have re-read more carefully your previous message. Sorry.
    I haven't, no. If somebody wants to check, I'll be happy to note results and see if I can do something about it.
    I have fixed it. I did not give a version bump as it seemed too minor a thing. If you download the zip files and reinstall it should be fixed. Hyprland compositor is now listed, both addons appear under my name and not Team LibreELEC (sorry, team, I really did not notice before) and dependencies for VacuumTubeMod now list Hyprland Compositor with the correct minimum version required.
    Edited 3 times, last by ashlar: Merged a post created by ashlar into this post. (November 20, 2026 at 12:13 AM).
  • I haven't, no. If somebody wants to check, I'll be happy to note results and see if I can do something about it
    Doesn't work on a mainline build, the same libXrender.so.1 missing error. You should be able to build Hyprland without any xorg deps.
  • Also be careful when doing non-clean rebuilds (i.e. when you don't wipe the build.LibreELEC... dir) - if at some point libXrender (or something else) got built and ended up in sysroot it'll be auto-picked-up by packages unless it's explicitly disabled in meson/cmake/... configure options.
    Hint: you can put sources and ccache directories outside of the build folder by setting the SOURCES_DIR, CCACHE_DIR and LOCAL_CCACHE_DIR environment variables, then you can simply nuke the current build.LibreELEC... directory and do a clean rebuild without needing to re-download all the sources or loosing ccache.
  • Doesn't work on a mainline build, the same libXrender.so.1 missing error. You should be able to build Hyprland without any xorg deps.
    I have bumped to 1.1.1 and included the missing libraries. It should work now.
    Hint: you can put sources and ccache directories outside of the build folder by setting the SOURCES_DIR, CCACHE_DIR and LOCAL_CCACHE_DIR environment variables, then you can simply nuke the current build.LibreELEC... directory and to a clean rebuild without needing to re-download all the sources or loosing ccache.
    I wish I understood even a single line of what you told me. And I thank you for telling it to me. I'm just no dev. I did this as a proof of concept and, since it works, I thought of sharing it. I don't have problems with conceptualizing software, but the coding... beyond me, totally. I'll try to understand what you wrote but I can offer no guarantees. I've been upfront about my ignorance since the beginning. :)
  • It's not about development, it's about building the binaries. And if you let your AI handle the building then just point it to the info - and tell it that should do a clean build from scratch (by deleting the build... folder before starting the build).
    Old relics in the build folder are the number one cause of build issues. Most of the time doing unclean rebuilds (with the build folder intact) work fine (and those rebuilds are quick), but pretty regularly they'll fail because of old stuff hanging around there - and of course with odd error messages (or weird libs getting picked up from sysroot).
    If you ever run into odd issues, first thing to do is delete the build folder and try again. If the issue persists, it's worth asking about.
    BTW: even we long-term devs sometimes get caught by these issues, our buildsystem doesn't handle dependency changes too well so nuking the build folder is necessary.
