[x86-64] Nvidia Suspend Problem
  • To upgrade with 12.2 version, i need to upgrade my video card. I install a nvidia GeForce GT1030. Power on without problem but resume from suspend fails with message : no video signal.
  • Test an LE13 image. You will need to cross-grade to Generic as Generic Legacy no longer exists. Clone your Kodi folder before to give a downgrade route. Any addons that depend on OpenGL should be removed first; leave settings and reinstall OpenGLES versions afterwards. There’s no guarantee this improves anything but LE12.2 is no longer being developed so best to test v.next.
    Found a best solution. I downgrade to 12.0. Older is better.
  • I got it. Since you don't have any competition, we have to shut our mouths. I do
    There are 20+ major distros that have a Kodi package. You are not forced to use LE; whatever works for you work for us.
    I did ask you to test the current LE13 image, but you refused. Triage 101: first eliminate all the bugs and issues fixed since the release the user is running by testing the current development release. Nobody has been developing the LE12.2 codebase for 18-months beyond bumping add-ons so even if a problem was identified it will never be fixed in that release.
    And nobody told you to shut your mouth, but we are all volunteers working in our often-limited free time. If you can't be arsed to help us with basic testing and information, we can't be arsed either.
