[S928X] CMA memory leak problem
  • Device: Ugoos AM8 Pro
    SoC: Amlogic S928X
    RAM: 8 GB
    Boot medium: microSD
    CoreELEC versions tested:
    22 Alpha 1
    22 Alpha 2
    22 Alpha 3
    22 Beta 1
    DTB: stock am8 DTB supplied with each respective release
    Kodi: bundled with CoreELEC
    Playback:
    Native Jellyfin integration
    Media stored on NFS mount (kernel-level mount)
    Display:
    1080p projector
    SDR only
    No HDR
    No Dolby Vision
    Problem
    During hardware video playback, contiguous CMA memory gradually decreases until Kodi crashes and the system reboots.
    Typical failure sequence:
    Video plays normally.
    Audio begins looping the last buffer.
    Screen turns black.
    Kodi crashes.
    Device reboots (watchdog).
    The problem only occurs during video playback.
    System is stable indefinitely when:
    idle (tested for 5 days)
    playing music
    browsing the UI
    CMA observations
    Initial:
    CmaFree ≈ 1985 MB
    During failing playback:
    44 min: CmaFree ≈ 1141 MB
    51 min: CmaFree ≈ 792 MB
    58 min: CmaFree ≈ 410 MB
    (examble on Sherlock Holmes 2009)
    After stopping playback:
    CmaFree recovers only partially (approximately 670 MB), never returning to the initial value.
    Starting another video after this can causes an immediate crash if little of memory was left.
    Normal system RAM does not show a comparable increase.
    Debugging performed
    Fresh SD card formatted before every installation
    No restored userdata
    Multiple CoreELEC versions tested
    Different Arctic and stock estuary skins tested
    Debug logging enabled
    CMA monitored through:
    grep -i Cma /proc/meminfo
    DMA-BUF inspection:
    cat /sys/kernel/debug/dma_buf/bufinfo
    Result remains constant:
    3 DMA-BUF objects
    ~87 MB total
    No increasing exported DMA-BUF count was observed.
    Kernel log before reboot contains only repeated:
    dim:warn:irq:flag 0
    No GPU fault, kernel panic, or OOM messages appear before SSH connection is lost.
    Codec testing
    Initially AV1 appeared stable, but further testing showed codec alone is not the determining factor.
    Failing file
    Alice in Wonderland
    MKV
    AV1 Main
    1920×1080
    10-bit
    23.976 fps
    AV1 codec string: av01.0.08M.10.0.111.01.01.01.0
    Video bitrate: ~8.18 Mb/s
    DTS-HD MA + DTS + AC3
    2 PGS subtitle tracks
    Result:
    Rapid CMA depletion
    Crash after approximately 20 minutes
    Working file
    Project Hail Mary
    MKV
    AV1 Main
    1920×1080
    10-bit
    24 fps
    AV1 codec string: av01.0.08M.10.0.110.01.01.01.0
    Video bitrate: ~0.77 Mb/s
    HE-AAC stereo
    35 SRT subtitle tracks
    Result:
    Over 2 hours playback
    No measurable CMA leak
    Additional testing
    Disabling subtitles does not resolve the issue.
    Hard factory reset, stock skin, file played from usb flash drive, movie stripped from everything except video track - no subtitles, audio, tags, chapters etc - leak stills occurred but slower
    FFmpeg software decoding reports no bitstream corruption.
    Audio playback alone never reproduces the problem.
    System idle for multiple days remains stable.
    Additional information
    Im not an IT person report above is an export from AI chat after 3 days of trouble shooting and hitting the wall time and time again - if any additional information is necessary, please word it in a way layman can understand.
    Approximately 80% (if not more) of my movie library of hundreds of movies are causing problems both files ripped from BD and transcoded by me as well as privatized from internet h264, h265, av1 all cause problems - tho movies and tv series with low bit-rate are in general less problematic than high quality rips
    older logs as i just wiped installation to try again with clean sheet and all logs perished but the SIGSEGV is consistent with current crashes - the Crash in FT_Done_Face / FreeType was resolved by overwriting subtitles styles
  • Umm... nice detailed report... but ...
    You know CoreELEC and LibreELEC aren't the same thing ? ... Right ?
    CoreELEC forked off from LibreELEC a good number of years ago (7-ish?) and had their own set of priorities they wanted to address.
    As a consequence the underlying Linux base, and the hardware it specifically addresses and the way they do it have diverged quite a bit.
    You might have more success addressing CoreELEC's community directly at https://discourse.coreelec.org/
    That said - this is not a "Get out of here, your kind is not wanted!" post, but more a note that people here may not have the detailed knowledge of CoreELEC's quirks and issues that you may need.
  • CoreELEC forked off from LibreELEC a good number of years ago (7-ish?) and had their own set of priorities they wanted to address.
    Tbh wasnt aware. Did thought that LibreELEC is making the base code that later on CE is striping down to bare bones so that it can run on 6yrs old android box with 4gb or RAM. I was convinced that Kodi team makes kodi, then Libre is making the OS out of it and then CoreElec is downsizing it (of course as a gross simplification but more or less my train though)
  • To copy/paste Google AI search:-
    "LibreELEC developers chose to prioritize a "mainline" Linux kernel, they intentionally discouraged or dropped deep development for Amlogic's proprietary hardware chips. The community created CoreELEC to keep the Amlogic platform alive and fully optimized.
    Unlike other systems that try to support everything, CoreELEC only targets Amlogic system-on-chips (SoCs). This tight focus allows developers to use Amlogic's official vendor kernels and specific hardware patches."
    In other words "LibreELEC didn't want to have to deal with and support Amlogic's weird proprietary shiznit"
    I'm sure some LE people will jump in and correct me if I've substantially mis-represented the case ;)
