Kernel drivers have interdependencies and probe order isn't guaranteed so it's quite normal to see "fail" or "timeout" or "deferred" on first probe until dependencies are resolved and then probe succeeds (often silently or with low noise) later in the sequence. So is there an actual problem?
LE13 on Radxa ROCK 5B+
atirage21 -
June 13, 2026 at 10:24 PM -
Only is not wakeup of this radxa from suspend after push power button, but is longtime issue.
Also i found h264 videos with aac audio, which runt freezing on start of playing with broken decoding. Here is one of them:
Display More2026-07-30 09:56:39.953 T:1530 info <general>: VideoPlayer::OpenFile: smb:// ...... Bodybangers - Europe ft. Victoria Kern, Nicco.mp4 2026-07-30 09:56:39.955 T:1850 info <general>: Creating InputStream 2026-07-30 09:56:40.163 T:1850 info <general>: Creating Demuxer 2026-07-30 09:56:40.195 T:1850 info <general>: Opening stream: 0 source: 256 2026-07-30 09:56:40.195 T:1850 info <general>: Creating video codec: mpeg4 2026-07-30 09:56:40.195 T:1850 info <general>: CDVDVideoCodecDRMPRIME::Open - using decoder V4L2 mem2mem MPEG4 decoder wrapper 2026-07-30 09:56:40.195 T:1850 info <general>: CDVDVideoCodecDRMPRIME::Open - unable to open codec 2026-07-30 09:56:40.195 T:1850 info <general>: CDVDVideoCodecDRMPRIME::Open - using decoder MPEG-4 part 2 2026-07-30 09:56:40.197 T:1850 info <general>: Creating video thread 2026-07-30 09:56:40.197 T:1860 info <general>: running thread: video_thread 2026-07-30 09:56:40.201 T:1850 info <general>: Opening stream: 1 source: 256 2026-07-30 09:56:40.201 T:1850 info <general>: Finding audio codec for: 86018 2026-07-30 09:56:40.202 T:1850 info <general>: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder aac 2026-07-30 09:56:40.202 T:1850 info <general>: void CVideoPlayerAudio::OpenStream(CDVDStreamInfo&, std::unique_ptr<CDVDAudioCodec>): Allowing max Out-Of-Sync Value of 50 ms 2026-07-30 09:56:40.202 T:1850 info <general>: Creating audio thread 2026-07-30 09:56:40.202 T:1861 info <general>: running thread: CVideoPlayerAudio::Process() 2026-07-30 09:56:40.212 T:1861 info <general>: Creating audio stream (codec: aac, channels: 2, sample rate: 44100, no pass-through) 2026-07-30 09:56:40.221 T:1653 info <general>: CActiveAESink::OpenSink - initialize sink 2026-07-30 09:56:40.240 T:1860 error <general>: CDVDVideoCodecDRMPRIME::FilterOpen - avfilter_init_dict: src: Invalid argument (-22) 2026-07-30 09:56:40.252 T:1530 warning <general>: bool KODI::WINDOWING::GBM::CDRMUtils::FindVideoAndGuiPlane(uint32_t, uint64_t, uint64_t, uint64_t): Cannot find a Video Plane [1920x1080] format:YU12, modifier:LINEAR together with a Gui Plane [1920x1080] format:AR24, modifier:ARM_BLOCK_SIZE=16x16,MODE=YTR|SPARSE. 2026-07-30 09:56:40.252 T:1530 error <general>: CBaseRenderer::GetShaderFormat - unsupported format drm_prime 2026-07-30 09:56:40.252 T:1860 warning <general>: CRenderManager::Configure - failed to configure 2026-07-30 09:56:40.252 T:1860 error <general>: OutputPicture - failed to configure renderer 2026-07-30 09:56:40.421 T:1653 info <general>: CAESinkALSA::Initialize - Attempting to open device "sysdefault:CARD=hdmi0" 2026-07-30 09:56:40.428 T:1653 info <general>: CAESinkALSA::Initialize - Opened device "sysdefault:CARD=hdmi0" 2026-07-30 09:56:40.428 T:1653 info <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats 2026-07-30 09:56:40.428 T:1653 info <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE4 2026-07-30 09:56:45.776 T:1860 warning <general>: OutputPicture - timeout waiting for buffer 2026-07-30 09:56:53.364 T:1684 warning <general>: Skipped 147 duplicate messages.. 2026-07-30 09:56:53.364 T:1684 info <general>: JSONRPC Server: New connection added 2026-07-30 09:56:53.364 T:1684 info <general>: JSONRPC Server: Disconnection detected 2026-07-30 09:56:53.365 T:1684 info <general>: JSONRPC Server: New connection added 2026-07-30 09:56:53.374 T:1684 info <general>: JSONRPC Server: Disconnection detected 2026-07-30 09:56:53.408 T:1860 warning <general>: OutputPicture - timeout waiting for buffer 2026-07-30 09:57:03.448 T:1860 warning <general>: Skipped 195 duplicate messages.. 2026-07-30 09:57:03.448 T:1860 warning <general>: OutputPicture - timeout waiting for buffer 2026-07-30 09:57:06.039 T:1530 warning <general>: Skipped 50 duplicate messages.. 2026-07-30 09:57:06.039 T:1530 info <general>: Loading skin file: SettingsCategory.xml, load type: KEEP_IN_MEMORY 2026-07-30 09:57:06.060 T:1860 warning <general>: OutputPicture - timeout waiting for buffer 2026-07-30 09:57:13.917 T:1530 warning <general>: Skipped 153 duplicate messages.. 2026-07-30 09:57:13.917 T:1530 info <general>: Log level changed to "trace" 2026-07-30 09:57:13.917 T:1530 info <general>: Enabled debug logging due to GUI setting. Level 2. -
Device is booting and going at nvme with spi 2.0 from armbian. Only new information, maybe is everyday for rockchips.
If is enabled drm prime then is netflix video not played. Tested also at last build from 12. august 2026.
Playing local h264 was solved with change direct to plane to setting of EGL. But for playing Netlix i have turn off whole DRM Prime.
With h264 in neflix are video not playing if is activated DRM Prime, If are av1 videos, then is playing with green artefacts.
https://paste.libreelec.tv/irrelievable-esme.log
https://paste.libreelec.tv/unmollifying-patience.log
https://paste.libreelec.tv/oafish-genevie.log
Code2026-07-26 16:44:31.885 T:1760 error <general>: CDVDVideoCodecDRMPRIME::FilterOpen - avfilter_graph_config: Invalid argument (-22)EDIT: after 2 minutes of playing of netflix is stoped video (audio and subtitles are going ok without video in gray colors) if was drm prime disabled.
https://paste.libreelec.tv/petalous-camron.log -
In code "error" denotes a code path ending. In some cases that it represents a fatal problem. In others it represents nothing more than reaching the end of a branch in some form of logic or decision tree. In this case the content is not interlaced hence opening the deinterlace filter (correctly) errors and playback continues.
Please repeat tests on the current dev image from my test share. I have little interest in current Rockchip nightlies as they use older kernel drivers and ffmpeg, etc.
OK, but there firstly i tested only as fresh install,... and i see big issue with turning off, which is freezing at black screen with title of build. Only after succesfully solution of turning off i will going to reinstall nightly build to development build.
And in case of problematic h264 local files (ff-mpeg4-drm_prime (SW)) with ativated drm prime and Direct to plane is not playing video:
https://paste.libreelec.tv/branchiostegous-kindra.log
Display More[ 125.938972] rockchip-drm display-subsystem: [drm] *ERROR* POST_BUF_EMPTY irq err at vp0 [ 125.939029] rockchip-drm display-subsystem: [drm] *ERROR* POST_BUF_EMPTY irq err at vp0 [ 125.939053] rockchip-drm display-subsystem: [drm] *ERROR* POST_BUF_EMPTY irq err at vp0 [ 125.939077] rockchip-drm display-subsystem: [drm] *ERROR* POST_BUF_EMPTY irq err at vp0 [ 125.939100] rockchip-drm display-subsystem: [drm] *ERROR* POST_BUF_EMPTY irq err at vp0 [ 125.939123] rockchip-drm display-subsystem: [drm] *ERROR* POST_BUF_EMPTY irq err at vp0 [ 125.939145] rockchip-drm display-subsystem: [drm] *ERROR* POST_BUF_EMPTY irq err at vp0 [ 125.939168] rockchip-drm display-subsystem: [drm] *ERROR* POST_BUF_EMPTY irq err at vp0 [ 125.939190] rockchip-drm display-subsystem: [drm] *ERROR* POST_BUF_EMPTY irq err at vp0 [ 125.939213] rockchip-drm display-subsystem: [drm] *ERROR* POST_BUF_EMPTY irq err at vp0 [ 129.258998] sched: DL replenish lagged too much [ 130.943985] vop2_isr: 729766 callbacks suppressed [ 63.553623] panthor fb000000.gpu: [drm] Firmware protected mode entry is not supported, ignoring [ 63.555403] panthor fb000000.gpu: [drm] Firmware git sha: 95a25d71030715381f33105394285e1dcc860a65 [ 63.560149] panthor fb000000.gpu: [drm] CSF FW using interface v1.5.0, Features 0x0 Instrumentation features 0x71 [ 63.560453] panthor fb000000.gpu: [drm] Using Transparent HugepageIf i changed direct to plane to egl, again is going with drm_prime also ...same behaviour as at LE13.
This ^ is completely harmless. Ignore.
According to AI Gemini is the reason for "turn -off issue" this error: rockchip-pm-domain ... Failed to create device link (0x180) with supplier 1-0042 which is connected with regulator fan53555
Recommendation for Kernel Maintainer from AI Gemini:
The boot logs highlight a probe ordering (race condition) issue on the Radxa Rock 5B+ (RK3588) running kernel 7.2.0. The rockchip-pm-domain driver attempts to establish device links before the corresponding PMIC suppliers are fully registered:
- Failed to create device link (0x180) with supplier 1-0042 for power-domain@8 (I2C FAN53555 regulator)
- Failed to create device link (0x180) with supplier spi2.0 for power-domain@12 (Main SPI PMIC)
Suggested Mitigation: Adjust probe dependency ordering or ensure proper probe deferral within the rockchip-pm-domain driver and power controller subsystem. The power-domain controller must defer initialization until the required suppliers (spi2.0 and I2C devices) complete their registration, preventing missing device links that break system shutdown and suspend states.
After 2 minutes playing of neflix at nightly build of LE13 with disabed drm prime are also issues.
Only for information about HW from Linux version 6.19.0 (ubuntu@843dd3320e8b) (aarch64-libreelec-linux-gnu-gcc-16.2.0 (GCC) 16.2.0, GNU ld (GNU Binutils) 2.47.20260726) #1 SMP Wed Aug 26 04:19:44 UTC 2026; Machine model: Radxa ROCK 5B+ :
Display MoreLibreELEC:~ # echo "Cortex-A55 (cpu0): $(cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies)" Cortex-A55 (cpu0): 1008000 1200000 1416000 1608000 1800000 LibreELEC:~ # echo "Cortex-A76 (cpu4): $(cat /sys/devices/system/cpu/cpu4/cpufreq/scaling_available_frequencies)" Cortex-A76 (cpu4): 1200000 1416000 1608000 1800000 2016000 2208000 2400000 LibreELEC:~ # > type=$(cat $zone/type) > echo "$type: ${temp}°C" > done package-thermal: 48°C bigcore0-thermal: 48°C bigcore2-thermal: 48°C littlecore-thermal: 48°C center-thermal: 47°C gpu-thermal: 47°C npu-thermal: 48°C LibreELEC:~ # lscpu Architecture: aarch64 CPU op-mode(s): 32-bit, 64-bit Byte Order: Little Endian CPU(s): 8 On-line CPU(s) list: 0-7 Vendor ID: ARM Model name: Cortex-A55 Model: 0 Thread(s) per core: 1 Core(s) per socket: 4 Socket(s): 1 Stepping: r2p0 Frequency boost: disabled CPU(s) scaling MHz: 100% CPU max MHz: 1800.0000 CPU min MHz: 1008.0000 BogoMIPS: 48.00 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp Model name: Cortex-A76 Model: 0 Thread(s) per core: 1 Core(s) per socket: 4 Socket(s): 1 Stepping: r4p0 CPU(s) scaling MHz: 50% CPU max MHz: 2400.0000 CPU min MHz: 1200.0000 BogoMIPS: 48.00 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp Caches (sum of all): L1d: 384 KiB (8 instances) L1i: 384 KiB (8 instances) L2: 2.5 MiB (8 instances) L3: 3 MiB (1 instance) Vulnerabilities: Gather data sampling: Not affected Ghostwrite: Not affected Indirect target selection: Not affected Itlb multihit: Not affected L1tf: Not affected Mds: Not affected Meltdown: Not affected Mmio stale data: Not affected Old microcode: Not affected Reg file data sampling: Not affected Retbleed: Not affected Spec rstack overflow: Not affected Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl Spectre v1: Mitigation; __user pointer sanitization Spectre v2: Vulnerable: Unprivileged eBPF enabled Srbds: Not affected Tsa: Not affected Tsx async abort: Not affected Vmscape: Not affected LibreELEC:~ # cat /sys/kernel/debug/clk/clk_summary | grep -Ei "gpu|vpu|vdpu|vepu|dmc|ddr" scmi_clk_gpu 0 0 0 300000000 0 0 50000 Y deviceless no_connection_id scmi_clk_ddr 0 0 0 0 0 0 50000 Y deviceless no_connection_id clk_ddr_cm0_rtc 1 1 0 32768 0 0 50000 Y deviceless no_connection_id clk_ddr_fail_safe 0 0 0 24000000 0 0 50000 Y deviceless no_connection_id clk_gpu_pvtm 0 0 0 24000000 0 0 50000 N deviceless no_connection_id tclk_wdt_ddr 0 0 0 24000000 0 0 50000 N deviceless no_connection_id clk_ddr_timer_root 0 0 0 24000000 0 0 50000 Y deviceless no_connection_id clk_ddr_timer1 0 0 0 24000000 0 0 50000 N deviceless no_connection_id clk_ddr_timer0 0 0 0 24000000 0 0 50000 N deviceless no_connection_id aclk_vdpu_low_root 1 2 0 396000000 0 0 50000 Y power-domain@21 no_connection_id aclk_vdpu_low_pre 1 6 0 396000000 0 0 50000 Y deviceless no_connection_id aclk_vpu 2 4 0 396000000 0 0 50000 Y fdb50000.video-codec aclk fclk_ddr_cm0_core 1 1 0 396000000 0 0 50000 Y deviceless no_connection_id hclk_vdpu_root 4 16 0 198000000 0 0 50000 Y power-domain@23 no_connection_id hclk_vpu 2 4 0 198000000 0 0 50000 Y fdb50000.video-codec hclk pclk_dma2ddr 1 1 0 198000000 0 0 50000 Y deviceless no_connection_id clk_gpu_src 3 3 0 300000000 0 0 50000 Y deviceless no_connection_id clk_core_gpu_pvtm 0 0 0 300000000 0 0 50000 N deviceless no_connection_id clk_gpu_stacks 2 3 0 300000000 0 0 50000 Y fb000000.gpu stacks gpu@fb000000 no_connection_id clk_gpu_coregroup 2 3 0 300000000 0 0 50000 Y fb000000.gpu coregroup gpu@fb000000 no_connection_id clk_gpu 2 3 0 300000000 0 0 50000 Y fb000000.gpu no_connection_id fb000000.gpu no_connection_id gpu@fb000000 no_connection_id aclk_vdpu_root 5 10 0 750000000 0 0 50000 Y power-domain@21 no_connection_id aclk_ddr_sharemem 1 1 0 500000000 0 0 50000 Y deviceless no_connection_id pclk_ddrcm0_intmux 1 1 0 100000000 0 0 50000 Y deviceless no_connection_id aclk_dma2ddr 1 1 0 702000000 0 0 50000 Y deviceless no_connection_id LibreELEC:~ # > echo "Zariadenie: $(basename $dev)" > echo " Minimálna: $(cat $dev/min_freq 2>/dev/null) Hz" > echo " Maximálna: $(cat $dev/max_freq 2>/dev/null) Hz" > echo " Governor: $(cat $dev/governor 2>/dev/null)" > done Zariadenie: fb000000.gpu Aktualna: 300000000 Hz Minimálna: 300000000 Hz Maximálna: 1000000000 Hz Governor: simple_ondemand -sh: Zariadenie: fb000000.gpu: not found Recommendations from AI gemini: 1. Core Settings Add-on (service.libreelec.settings) Issue: Focus navigation failure on Control 1000 (window 13001) caused by a malformed JSONRPC type definition (Setting.Details.SettingList). Action: Update Python API bindings in service.libreelec.settings to align with Kodi 22 RPC schema changes. 2. Missing XKB / Locale Definitions Issue: XKB Compose table compilation fails due to missing en_US.UTF-8 locale definitions and an uncreated /storage/.config/xkb path. Action: Bundle default locale files and pre-create the /storage/.config/xkb directory structure in the LibreELEC buildroot target image. 3. Audio Subsystem Initialization (ALSA/PulseAudio) Issue: Log reports load failure for module-allow-passthrough, triggering an unexpected audio output fallback from the internal rk3588es8316 codec to hdmi0. Action: Refactor default.pa / ALSA configuration for RK3588 targets to prevent loading unavailable passthrough modules on the ALSA layer. 4. Mainline Kernel Device Tree (DTS) — DMC / RAM Scaling Issue: devfreq only exposes the GPU (fb000000.gpu). The scmi_clk_ddr node reports 0 Hz, leaving the Dynamic Memory Controller (DMC) without active DVFS scaling in kernel space. Action: Mainline missing SCMI and DMC nodes along with proper clock bindings in the RK3588 kernel Device Tree. 5. SATA/ATAPI Optical Drive Handling (/dev/sr0) Issue: dll_ioctl I/O error (code 5) occurs when reading sector VIDEO_TS.IFO, breaking libdvdread and forcing DVD media misdetection as an 18-track Audio CD. Action: Patch the RK3588 PCIe-AHCI driver to ensure correct SCSI/ATAPI command execution and error handling for optical drives. 6. Kernel Hardening — eBPF Security Mitigation Issue: Spectre v2 mitigation check reports Vulnerable: Unprivileged eBPF enabled. Action: Set CONFIG_BPF_UNPRIV_DEFAULT_OFF=y in the LibreELEC RK3588 kernel defconfig to restrict unprivileged eBPF access. -
To be crystal clear, I have zero interest in bug reports against this kernel as it's about to be superseded with the 7.2 kernel as used in the images from my test shares. Dealing with temp things is a low priority to investigate, so repeatedly posting the same "still not working" post is just becoming annoying. I also haven't read the AI-slop 'guidance' posted, because Gemini is total garbage.
I wrote and sent logs from beta testing build which had turn off issue. Through AI i found some files which was updated last time for rockchips: https://github.com/rockchip-linux…se/RK3588_EN.md
In repo of libreelec i saw only 6y old rkbin: https://github.com/LibreELEC/rkbin-extra
Work developers is really the most important. But Gemini is interesting utility for creating own projects (i am not programator):
1. i found through gemini right components for my hobby project : DVD (with replacibility to blu-ray) player based on KODI
2. It create code for Arduino Mikro Pro for using of analog and IR buttons of old nonfunctional panasonic player.
3. It create links between Arduino and Kodi for right behaviour of Kodi at push of analog or original panasonic IR button. I uploaded files which i used in LE 13 and succesfully works (only for case of interest).
I am really happy that exist Gemini, Libreelec, and many opensource projects.
UART TLL logs from LE 13 Nigthly build (is going from NVME) and Last testing build (going from SD card)
Please only inform me, if was dtb updated according to information of TTL due to next testing. Last dmesg log from build of 10. october 2026.
Thank you!
https://paste.libreelec.tv/vivacious-tajuana.log
I see errors of rockchip-drm display-subsystem: [drm] *ERROR* POST_BUF_EMPTY irq err at vp0. If you know, please send me some commands, which can help to findinging of solution through e.g. TTL logs. Here i uploaded DRM logs from LE 13 Nightly with kernel 6.19.
