OK, I thought something like it was missing!
I only have routing issues with wireguard; normally no issues on other systems. Have you experienced this ?
Thanks so far; maybe this needs to be added to your Wiki including the config template ?
Routing issues is not wireguard if your wireguard config file has settings for a VPN provider it is OK. It is connman that handles the routing. Do this cmd in ssh before connecting to a VPN:
Then connect to your VPN and do that "route" command again provide that here so I can see. And provide the wireguard file note edit your WireGuard.PrivateKey = ******* we do not need that!
