[x86-64] Connection issues of bluetooth headphones and buggy remote
  • Hi
    Recently i build out of old pc components small nice media pc. Everything working pretty well but there are 2 problems that annoys me.
    1. I’m using wirelesses Bluetooth headphones, and i have to connect them manually every time i turn on the machine. Its kinda annoying, wireless mouse work fine, but headphones just wont cooperate. Sometimes i have to remove them and them press connect and trust. Is there any solution for this?
    2. Using android remote app is like dealing with the cat. 2 days ago everything worked fine using Yatse: Kodi Pilot, but yesterday i couldn’t reach machine at all. Its like didnt feel it that day, and refuse to cuddle. I tried with official kodi remote and it have same results. Feels like there is something with connection, not apps.
    System version Generic-legacy.x86_64-12.0.2
    Also somebody make YouTube easy to install plz
    Thanks in advance
  • YouTube will never be simple to install because Google charges for API based searches. The add-on embeds pre-configured API keys but these have a limited free search quota per 24h period and Kodi has a large userbase so the quota is exhausted within minutes of resetting. The cost of providing paid-for 'free' search for Kodi users would require considerably more revenue than the income Kodi generates from t-shirt sales and public donations. Kodi also has an open-source add-on ecosystem so if we funded API keys in the YouTube add-on, they are not secure and will be instantly stolen and reused by other apps and services (this already happens with the pre-configured ones) with their quota consumption charged to Kodi. If you want easier Google services, the only realistic option is to use the native apps on Android, as then Google provides free access to its own services because "If the service is free, You're the product" is one of the foundation principles of their business model.
    For BT problems; delete the device and then redo pairing and (separate) trust using bluetoothctl from the CLI over SSH and see if that then works better. Headphones normally need pair/trust relationships.
    If multiple phone apps aren't working, perhaps:
    • There's a general issue within your network, e.g. multiple routers and incorrect subnet routing
    • Common security or network settings on the phone, e.g. VPNs which route traffic down a tunnel
    • There's an issue with config/settings on Kodi - I'd ask for debug logs but they're unlikely to show anything useful
  • Thanks for quick response.
    I managed to fix the remote problem by enabling password requirement. Weird but worked.
    The Bluetooth headphones didn’t worked. Did ssh root ip adress>bluetoothctl>devices>Device mac address>remove mac address , then scan on>pair>trust. Headphones just blinked
    Which log files i need to paste? Got couple of them. Kodi.log, kodicrash.log, System,Hardware,Audio,Newtork,varlog,input,filesystem,journal-cur
  • Which log files i need to paste? Got couple of them.
    Debug log.
    How to post a log (wiki)
    2. Restart Kodi
    3. Replicate the problem
