[x86-64][LibreELEC x CB1 Builds] Dolby Vision FEL, HDR10+ and Full 3D
  • I don't know what "other" represents, I don't know if it matters.
    On the HDR10+ circuit you selected in the screenshot, it's standard Kodi pipeline without any modification. I have a Kodi update coming in the next release; maybe it will fix your signal recognition problem.
    Usually it would show as 4K24. I just found it odd that the Anthem didn’t recognize it. 4k60 is also showing as 4k24. I tried to see if I can download a log or report from the Anthem. But there is no option. It doesn’t really matter as long as the displays see it correctly, which both the JVC NZ800 and Xgimi Titan Noir do. I think its a better example of how temperamental the Anthem can be.
    Regardless, thank you for all this work. Looks amazing.
  • Usually it would show as 4K24. I just found it odd that the Anthem didn’t recognize it. 4k60 is also showing as 4k24. I tried to see if I can download a log or report from the Anthem. But there is no option. It doesn’t really matter as long as the displays see it correctly, which both the JVC NZ800 and Xgimi Titan Noir do. I think its a better example of how temperamental the Anthem can be.
    I used to use an Anthem receiver and it had little issues like that a lot. never figured it out but all signals passed through it just fine regardless of what it reported.
  • So, while 3D like below that are 4K 3D 60fps (not using app above) do play on my H255, playerprocessinfo won't show (hitting 'O' does nothing), and ff/rew and chapters skips are slow. Probably unsurprising...
