Dolby Vision w/FEL + 3D for PC (AMD/Intel/nVidia)
  • As good as SmartTube. Only thing is w/it, you can set it to go to your subscriptions tab upon start. Not seeing a way to do so with VacuumTube. Having it integrated into Kodi is a huge plus vs a separate app like w/Android.
    this is great news, feels like a dream how fast this happened! also if you know how or can use AI, you can set a button on your remote to load YouTube addon. You'll have to change your keyboard.xml and figure out the command to launch and the command for your key. using AI it would help you and guide you. as soon as you press the button it will stop kodi and load YouTube. once you do that, you can start customising more menus, like a button to load your library etc. But the YouTube button will make it feel instant when you want to go into YouTube.
    for the other parts, you can mess around with AI to see if can help. send the source code to chatgpt and ask
