Audio output resets across reboots
  • Hi folks, long-time user, first-time caller. I recently replaced a Raspberry Pi 4 which was running Kodi with a ThinkCentre; I got tired of the rPI's poor WiFi and tendency to hang and need a reboot.
    The new setup isn't working as well as I hoped. Every time I reboot the machine, it plays audio through the (terrible) internal speaker, instead of over HDMI into my receiver. if I go into settings->system settings->audio, the audio output device is set correctly ("ALSA: HDA INTEL PCH, MJI MARANTZ-AVR ON HDMI #0"), though it isn't actually used. Fixing this requires changing the output device to something else, then back to the receiver, after every reboot.
    Seems like a bug to me, but is this known / is there some kind of workaround?
    Using LibreELEC 12.2.1 generic.x86_64, hardware is a ThinkCentre M720q (i5-8400T w/ 8gb RAM).
