Escalade can you give me a run through on what to do because I've tried everything, I've re flashed my intel nuc 5 times with no success in regards to the emulators, everytime I click on the tab it does nothing
escalade -
May 12, 2016 at 2:26 PM -
Thread is Resolved
20170516 fixed build uploadedWhat does this mean? Fixed my problem?
i got controller to work finally, won't work unless u manually bind keys pushing the controller. after that got the asound.conf working so now sound in games great. seems like I can browse retroarch and use the A button on controller to run games as well which rocks. but this is a little complicated for the kids. will emulationstation be fixed in next build escalade
I'm running 20170516 on my NUC and Emulationstation runs fine.
I'm not on 0516 this time, but with 0512 ES also doesn't start
Upgrade
I'm running 20170516 on my NUC and Emulationstation runs fine.Cam you tell me how you set yours up please because I'm on the updated version and it still dosent work, no emulationstation or retroarch, nothing in there folders either to try and run them
I don't know what to tell you, it works here launching from main menu.
I don't know what to tell you, it works here launching from main menu.A run through from the beginning on how you set it up might help me, especially as you have a intel nuc like me
when I try start "emulators" doesn't work, i can change to retroarch it works.
not with emulationstation never -
interesting, chrome and spotify are definitely not in the menu. Emulators is at the bottom, but those two things are not. My menu looks like:
- Movies
- TV Shows
- Music
- Music Videos
- TV
- Radio
- Add-ons
- Pictures
- Videos
- Favourites
- Weather
- EmulatorsCould I have somehow not installed them? The about says devel-20170506, I'm using a rpi2
Chrome is only for x86, not supported on rpi2.
I'm using AMD Kabini processor with the radeon gpu. It should work I think. I have Chrome and Spotify, just when I click Emulators with remote nothing happens, please fix
I'm using AMD Kabini processor with the radeon gpu. It should work I think. I have Chrome and Spotify, just when I click Emulators with remote nothing happens, please fixMines intel, but the problems the same
Again, I have 20170516 on my NUC and clicking Emulators launches ES as it should. So make sure you're on the right version and provide logs.
# LibreELEC #
# LibreELEC – Just enough OS for KODI #
##############################################LibreELEC (community) Version: devel-20170516
LibreELEC git: 97d00948025937f178536ded9809c318311880a0LibreELEC:~ # cat /tmp/emulationstation.log
terminate called after throwing an instance of 'std::runtime_error'
what(): locale::facet::_S_create_c_locale name not valid
Aborted (core dumped)it does look like some sort of runtime environment issuee. I actually tried setting some sort of environment variable:export LC_ALL="en_US.UTF-8"
Ok, I see the problem now. New build coming soon
Ok, I see the problem now. New build coming soonawesome , thanks
