Having the ability to control or turn off the LED of the GTX video cards would be nice.
If this can help; GitHub - Madh93/nvidia-led: Awesome effects for NVIDIA GeForce GTX LEDs
		GTX LED Visualizer
						vitorp07
					December 14, 2016 at 4:52 AM
			- Official Post
 nvidia-led/nvidia-led.sh at master · Madh93/nvidia-led · GitHub  it's a shell script that sends commands to nvidia-settings. Just modify the path in line 4 (styles=) and it should run on LE without changes. it's a shell script that sends commands to nvidia-settings. Just modify the path in line 4 (styles=) and it should run on LE without changes.
			- Official Post
 nvidia-led/nvidia-led.sh at master · Madh93/nvidia-led · GitHub it's a shell script that sends commands to nvidia-settings. Just modify the path in line 4 (styles=) and it should run on LE without changes. it's a shell script that sends commands to nvidia-settings. Just modify the path in line 4 (styles=) and it should run on LE without changes.we don't include nvidia-settings at all so no matter what it won't work.
 Thanks@lrusak Is it possible to create an addon with that script then and would it work?
 Is this the nvidia-settings in question? Index of /XFree86/nvidia-settings
			- Official Post
 How about a piece of duct tape?
			- Official Post
 Ahh.. my bad, it's nvidia-xconfig that we include not nvidia-settings. The nvidia-settings code requires Qt and a load of other not-otherwise-needed stuff to run so it could be packaged up as an add-on, but this probably needs to be a user-community effort as I'm not sure any of the core devs will be too interested in the task. It might be worth seeing how nvidia-settings actually implements the LED status changes as it's probably just code wrapping to simplify setting of things via other means.
 I will try to make an addon with that then.
 Thanks for your clear explanation
