[x86-64] MP3 Playback Crashes on HP T630 and T620
  • We are talking about 1000 MP3s in different directories and different origins. (Not from One-File MP3 and cutted)
    My feeling was that it is mostly crashing when switching to another song but it also happened in the middle of one song which i remembered and then played again after restart, but the chrash did not occur again ...
    I checked them all with foobar and there have been issues which i all now corrected, so i will try them again.
    I also downloaded sample MP3s from the link above (Hungry Lucy is ok, right ?) and will test them also.
    I will come back with further news
    Thanks for the support ...
  • If there's a suspicion on Goom, a couple of things to experiment with:
    a) Switch to another visualisation for a few days. If the issue still happens it's not specific to Goom. If it doesn't it points the finger more firmly towards Goom.
    b) Change Goom settings to manual and work your way through the list of individual visuals. Each one uses different shaders so can potentially result in different behaviour. The theory is that something in the shaders (which have seen quite a bit of change for K22 might disagree and cause issues. See if you can pinpoint specific visuals that cause problems.
    NB: I've also seen the errors related to ID3 tags, but if the software is flagging those issues it suggests it's reading the file and then reporting; which suggests gracefull handling of those issues and thus (IMHO) they aren't likely to be the cause of a crash.
  • It happened also with Fish BMC visualization in LE13.
    I thought it was better after repairing some of my mp3's but it happened again just one hour after start playing.
    Log before chrash : https://paste.libreelec.tv/amused-dodo.log
    Log after crash : https://paste.libreelec.tv/pleasant-ant.log
    Crashlog : https://paste.libreelec.tv/alert-impala.log
    I will try the downloaded "Hungry Lucy" over night because this is not my favorite music to hear ...
    Edited 2 times, last by JoeCotty (March 2, 2025 at 1:54 PM).
  • Da Flex
    From where dou you get the information in the log, that the crash is related to FFMPEG.
    I started Hungry Lucy in the evening yesterday with her 10 songs and she still was singing today now in the morning.
    So what i did is removed all unwanted ID3 tags with "mp3tag" from my songs like "APE" and "ID3v1" and also deleted unneeded fields inside.
    So i only now have only about 7 fields inside my songs like "artist" and "title" or "Genre", "unsyncedlyrics", "year", gain ...
    but still crashes.
    So now i want to reduce the amount of songs and only let play one directory with about 50 songs in concrete order.
    So i hope i can reproduce it with less songs and find the root cause ...
  • Da Flex
    That's not a fact, just a theory. Kodi crashes by "segmentation fault", so I guess the FFMPEG error "[mp3float] Header missing" leads to wrong memory management. The other errors in the log are more common, and well known.
    If you can separate an MP3, which generates the error, try to play it as a loop, until it crashes the system. That's the MP3 we need to reproduce the bug. It's probably copyright protected, so I guess we have to share the file in private mode. Don't post it here.
  • I can now reproduce the crash but it was very very tricky ...
    So prepare for a post with much reading and thinking ....
    Found a song which causes the crash but playing it standalone does not crash Kodi ...
    So what i tested finally (after many many hours) with 3 files in one directory :
    1.)
    playing song1, chrashsong, song3 -> crashsong (4:38) crashes always at 4:28
    playing chrashsong -> nothing chrashes
    playing song1, chrashsong -> nothing chrashes
    playing chrashsong, song3 -> nothing chrashes
    !!! Unbelieveable. thats why i did not find a single song which causes the crash !!!
    2.)
    Changed song1 and song3 to another song -> same behaviour like above
    3.)
    I remembered i have crossfade activated between songs with 5s so i deactivated it
    playing song1, chrashsong, song3 -> song 3 starts but when i used keyboard to go back also Kodi crashed
    4.)
    Activated crossfade again but with 10s
    playing song1, chrashsong, song3 -> crashsong (4:38) crashes 5s earlier at 4:23 like expected
    5.)
    crossfade back to 5s
    I reencoded crashsong with foobar and lame 3.100 to 190K
    playing song1, new encoded chrashsong, song3 -> also chrashed
    6.)
    Saw that crashsong had 48 KHz and the rest 44.1 KHz
    Now reencoded the crashsong with ffmpeg to 44.1 KHz
    !!! Yeah, now these 3 songs are runnning without crash ... !!!
    So i will reencode all 48 KHz songs to 44.1 KHz and then test all songs again.
    Hopefully this was the root cause for all the crashes
    There have been approx 30 songs with 48 KHz in my list of about 1000 (most of them converted online out of youtube videos ...)
    But a 48 KHz mp3 should not be a problem for Kodi, or ?
    Finally my about 1000 songs played now for about 20 hours without crash ...
    So my already new bought hardware T730 is no more needed ....
    Shall i provide these 3 songs and if yes how ?
    Best regards
    Joe
