[RPi5] HDMI CEC Problem
						Gaffer
					September 12, 2024 at 2:36 PM
													Thread is Resolved
			Use LE 12 nightly instead. Thread[RPi4] Multiple CEC Adapters with LE 12.0.1I'm looking for some CEC related help.
 Ever since upgrading to 12.0.1, I have two CEC adopters in the Input > Peripherials menu, and they just don't co-oporate. I tried disable on of them in the menu, reboot and both are back active. How can I disable one of them?silentsoundAugust 29, 2024 at 4:00 PM
			Hi. Found this via the linked issue (Multiple Adapters...). Thanks for the quick fix, is the nightly likely to cause problems on the Pi5 in other aspects, or can I install it without needing to be worried? Will there soon be a 12.0.2 that includes this fix? Thank you so much for your hard work on LibreELEC which is IMHO the supreme implementation of Kodi. So awesome.
			imforumman Our nightly builds run pretty stable. You can go back to 12.0.1, if needed. No ETA for 12.0.2. From SSH:
			Thanks, I've switched to using the nightlies you linked to (one RasPi4 and two RasPi5) and a couple of test runs have shown no awkward behavior. Thanks again so much.
